03-23-2022, 02:10 PM | #1 |
60 ft. times - Suspension Recommendations
In man's eternal search for improved 60 ft. times, BMR has made the following suggestions:
BK063 Bushing Kit, Rear Cradle, Lockout BK060 Bushing Kit, Differential Lockout, Aluminum UTCA063 Upper Control Arms, On-car Adjustable, Rod Ends UTCA060 Upper Trailing Arm, On-car Adjustable, Rod Ends TCA061 Lower Trailing Arms, On-car Adjustable, Rod Ends BMR should know this topic well. What do you think? There's already a thread on this at https://www.camaro6.com/forums/showt...2#post11149962
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 03-23-2022 at 05:00 PM. |
03-23-2022, 04:51 PM | #2 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
It depends on your HP IMO, I would go with the BMR Suspension BK063 Rear Cradle Lockout it’s definitely stiffer ride but it plants your rear end and gets rid of wheel hop. Not sure about the other stuff never tried them.
103 Katech TB, KATECH Custom Heads TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 98 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
03-23-2022, 04:59 PM | #3 |
Almost 900 hp. I've seen a lot of positive comments on BK063 from guys who have installed it, and that's a really good endorsement, along with BMR's recommendation of course.
'20 ZL1 1LE A10,
03-25-2022, 07:37 AM | #4 |
Umm, ZLE already has aluminum cradle bushings from the factory.
Have you raced the car with the unlocked and now tuned trans yet? Because obviously the short times with a locked trans on a ZL1 are disappointing, this is well documented. |
03-25-2022, 05:25 PM | #5 | |
https://www.camaro6.com/forums/showthread.php?t=553258
03-25-2022, 06:03 PM | #6 | |
03-25-2022, 06:28 PM | #7 |
Much appreciated for you pointing this out twice to me. I was referring to the discontinue thread on my last message that’s all.
03-25-2022, 06:28 PM | #8 | |
Thread Tools | |
