02-25-2022, 08:04 PM | #1 |
It don’t come easy.
Sparks 2014 - 2015 SS emblem on a 2010
For those who are still looking for an SS emblem for their 2010, Sparks no longer makes that year (2010 - 2013).
I’m in the process of making the 2014 - 2015 emblem work on my early build 2010 ( locating holes in the trunk lid). There will be some machining involved to the emblem. I’ll post pics as I go along, for those that this would be helpful to. Bowtie removed.
02-25-2022, 08:09 PM | #2 |
It don’t come easy.
The ‘14 emblem is basically flat, so it’ll have to be machined in order to sit on the body work correctly. Approximately 4.5 degrees from center to the outer edges of the emblem should be close.
02-26-2022, 01:41 PM | #3 |
It don’t come easy.
Setup on my mini mill.
02-26-2022, 01:48 PM | #4 |
It don’t come easy.
5 degrees put it right on the money with my trunk.
It will cover up the right hole but, won’t quite cover the left hole on the trunk. I’m thinking something as simple as a piece of yellow tape will hide it. Need it to be a tad warmer before going any further, as I want the 3M tape to stick on the emblem.
Last edited by 0stones0; 02-27-2022 at 02:23 PM. Reason: Better pic of machined angle. |
02-26-2022, 01:59 PM | #5 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
When you have it down ...
Can you please measure the holes? I have one vision, but I don't know if I would cover the holes because I don't know how big they are.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
02-26-2022, 04:09 PM | #6 |
It don’t come easy.
3.95” to the center of the holes.
4.40” to the outside of the holes. Is that what you need George?
02-27-2022, 01:56 AM | #7 |
👌And diameter of holes? 🙏
02-27-2022, 07:58 AM | #8 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
George, I put the image in autocad & scaled it to the dimensions 0stones0 provided. It should be very close. Maybe this will help other members as well.
02-27-2022, 08:31 AM | #9 |
It don’t come easy.
Almost right on the money Acutron!
Left concentric hole you are correct - .315 Right oblong hole - width = .535. height = .405
02-27-2022, 09:09 AM | #10 |
10 mm does look better for the oblong hole. It's hard to tell with the paint. Gm might have used fractional punches but I figured metric. I hope this helps!
02-27-2022, 10:54 AM | #11 |
It don’t come easy.
Removed the small SS emblem to accommodate the new one.
02-27-2022, 11:09 AM | #12 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
You’re doing a great service to the forum. I can’t believe they stopped making them though. Makes me glad I got mine a few years ago.
02-27-2022, 11:14 AM | #13 | |
Thank you 👍👍👍🤜🤛
02-27-2022, 02:02 PM | #14 | |
It don’t come easy.
I just couldn’t find anything remotely I liked that came close to the styling and build quality of the Sparks emblem. The real problem is the holes in the trunk. Is what it is.
