10-06-2021, 07:58 AM | #43 |
How much would the pressure change from that point to the sensor and would that be measuring at the output side of the pump? If that is directly off the pump, couldn't there still be other problems within the engine that cause a loss of pressure between there and the rest of the engine?
Of course low pressure there would definitely indicate a problem. |
10-06-2021, 08:07 AM | #44 | |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
10-06-2021, 08:36 AM | #45 | |
Drives: 2010 Camaro SS Join Date: Dec 2006
10-06-2021, 11:14 AM | #46 |
All right guys. I managed to get my pressure gauge hooked up where the sensor goes and when I cranked it my oil pressure shot up to 70 psi. The gauge in the car would only go up to 50 cold. So right then I realized that the pressure sensor was reading incorrect. So I already had a new sensor and managed to get it on. When I re-cranked it my gauge in the console shot up to 70 psi just like the mechanical gauge. So I took it for a drive for about 30 minutes to get the oil hot and wouldn't you know it reads 33 psi at idle, at cruising it sits at 50 psi, and at wot it goes to 80 psi.
So now I feel like a dummy. All you guys kept saying hook up a gauge hook up a gauge, and I kept on thinking there's nothing wrong with that darn sensor. I thought it was going to be a lot tougher than that to change it out. So I would personally like to thank you guys from the bottom of my heart for all your help. So now I need to change those damn lifters. Now that's going to be a job!
10-06-2021, 12:31 PM | #47 |
Drives: 2015 1LE Join Date: Oct 2015
Change the lifters for what reason?
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
10-06-2021, 12:37 PM | #48 |
I've got a couple that have gotten consistently louder and louder since my cam install. I thought that I had purchased gm performance racing lifters, but I actually got just the gm performance lifters and I don't trust them.
10-06-2021, 05:39 PM | #49 |
From my research, the Johnson 2110 lifters are supposed to be pretty good. I’ve got a set sitting in the garage waiting to go in my build. So I can’t personally vouch for them from experience. But that’s what I’m going with. Hard to find lately. But Scoggins Dickey had them in stock as of about a month ago.
10-07-2021, 12:15 AM | #50 | |
10-07-2021, 06:06 AM | #51 | |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Piss in the bucket ,lots of great feedback on the Johnson's over at LS1Tech. Spend the money now and save a PITA later.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
10-09-2021, 07:16 PM | #52 | |
I have heard good things about the GM/Cadillac Racing lifters, but I also hear they are noisy. I hear nothing but great things about Johnson Lifters.
10-09-2021, 09:48 PM | #53 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
You might just need to go to next size longer pushrod!
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
10-10-2021, 12:02 AM | #54 | |
Yeah I'm gonna check preload when I change them.
10-20-2021, 02:18 AM | #55 |
Just an update. I just got done with my lifter change today. I went with the gm performance racing lifters. Well they sound way better then the regular gm performance lifters. No more loud tapping. Their quieter at idle and definitely quieter at cruising speeds. Thank goodness. One thing though I can't figure out is why their quieter, because the ones I took out still look brand new on the rollers and the cam lobes also look new too. Maybe something internal in the lifters? Idk.
10-21-2021, 10:56 AM | #56 | |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
