05-18-2021, 02:57 AM | #1 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
trans cooler
I got this little guy last night.
Any tips for installation?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
05-18-2021, 04:01 AM | #2 |
Drives: 2012 Camaro SS Join Date: Dec 2019
https://www.camaro5.com/forums/showthread.php?t=588076
How I did mine I added a link to the part I used. Watch a video on YouTube how to remove bumper it’s very easy. Also use thread tape sealant on the threads before you screw it into the cooler and don’t over torque it.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
05-18-2021, 04:10 AM | #3 |
Thank you sir.
05-18-2021, 07:10 AM | #4 |
Also the drivers side is the return line. You want it to go into the radiator first then out (drivers side) then into the cooler then back to the line you took off of the drivers side. I mounted mine with self taping screws that are provided, I just started a whole with a drill. Went in easy and is solid, and used zip ties to keep the lines snug and not rubbing against anything.
05-18-2021, 08:11 AM | #5 | |
Drives: 15 Camaro SS Join Date: Oct 2018
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
05-18-2021, 08:12 AM | #6 |
https://www.camaro5.com/forums/showthread.php?t=568830
There you go. Its early on in the build, end of page 2 into page 3
05-18-2021, 08:21 AM | #7 |
Thanks a lot for the info guys.
05-18-2021, 08:54 AM | #8 | |
Another great way to install it ^ Where I got inspiration from to do it lol. Must say these tru cool 40k are legit. Don’t ever go above 180 and that’s in traffic.
05-18-2021, 01:13 PM | #9 |
I was wondering if I could cut the return line that goes from the radiator to the transmission and flare both the cut ends and connect the hose provided to the flared ends?
05-18-2021, 04:51 PM | #10 |
You can or buy a compression fitting with a hose nipple on it. I just lubed it up and pushed it over the the old hose (past the nipple) and put 2 hose clamps on it. Solid and no leaks and I drive my card hard every time I get in it lol.
05-18-2021, 06:40 PM | #11 |
ok I'll look into that. I am trying to find a solution to do this install with just the parts from the local parts store because I don't really have time to wait for an order to come in. lol
05-18-2021, 07:54 PM | #12 |
Hey I actually found that fitting that you posted from Amazon at O'Reilly auto parts. They just had to special order it and it will come in tomorrow morning. I'll post some pictures of the install when I get a chance.
05-18-2021, 09:24 PM | #13 |
Yup! I dont think ive seen a temp above 180 yet, even on 90+ degree days in traffic
05-19-2021, 02:40 AM | #14 |
That's great to here because I've been running around 200-210* on hot days here in Texas and it's still in the 80's right now but it's gonna get to 100* this summer. Did you run yours through the radiator also?
