04-01-2021, 02:49 AM | #1 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Z28 Wheel size
Hey guys I have a 2012 Camaro SS with it looks like the 2015 Z28 wheels on it. Well my son has a new 2021 Camaro and wants some wheels like mine but I'm not sure what size they are. They are 20" matt black with 305X35 in the rear and 285X45 in the front. Can anyone tell me by the tire size in the rear, what the wheel size is? Or can I just put a tape measure through the holes in the wheel and get an accurate measurement that way? Thanks
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
04-01-2021, 05:32 AM | #2 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Probably 10's and 11's but could be 9's and 10's
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
04-01-2021, 06:04 AM | #3 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
If they are 20", they are not original Z28 wheels. I think they are MRR and you should be able to find their specs on here.
Sent from my Pixel 5 using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
04-01-2021, 06:05 AM | #4 |
Drives: 2015 Z/22 Join Date: Aug 2015
285/35 (are they 285/45 or 35?) on 20x10 front and 305/35 on 20x11 rear are the factory ZL1 tire and wheel sizes so they're probably 10 and 11 wide.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
04-01-2021, 06:33 AM | #5 |
yeah there 285/35 in the front. bf Goodrich comp-2. so I seen some on the web with those size tires that are 20X10 and 20X11 and 20X9 and 20X10. would a 305/35 fit on a 10" wheel?
04-01-2021, 07:00 AM | #6 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Yes, that is the min width spec for many 305/35s
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-01-2021, 07:43 AM | #7 |
04-01-2021, 07:53 PM | #8 |
I ran 315/35's on all the 10" wheels I had on the car with no issues..
04-01-2021, 09:31 PM | #9 |
wow. I didn't think that was possible.
04-02-2021, 09:00 AM | #10 |
Yep, and lowered 1.25... American Racing VN805 Boulevards, 20x10 rear's.
04-02-2021, 01:28 PM | #11 | |
04-02-2021, 03:26 PM | #12 | |
04-03-2021, 06:23 AM | #13 | |
04-03-2021, 08:19 AM | #14 |
Hey thanks, me too. The chrome was a BITCH to take care of!! Yea I bought the ones I have now from MRR Designs and had them polished and clear coated by them. Very easy to take care of.
