03-04-2021, 01:02 PM | #29 |
I have the Melling in my engine but not sure which one it is. Idling warm it sits at 32-35psi and when cruising at 2000rpm it sits at about 55ish. Cold start she is at 65 or so then drops back down when the oil is up to temp. 5w30 Mobil 1.
03-04-2021, 01:05 PM | #30 | |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
03-04-2021, 01:08 PM | #31 |
Thank you for the numbers but I would need to know which oil pump you actually have to be of help.
03-04-2021, 01:20 PM | #32 |
You're welcome, I will see if my shop remembers which one they installed.
03-04-2021, 01:24 PM | #33 | |
Drives: ABM #93 Join Date: Oct 2018
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
03-04-2021, 01:33 PM | #34 |
I just chatted with my builder and they installed the 10295 in my engine. He also said that is the one they use to replace the LS3 ones. He also said that if you are an L99 you could use the 10296 and it would be the same as the stock L99 pump replacement. Hope this helps you out.
03-04-2021, 01:37 PM | #35 | |
03-04-2021, 01:47 PM | #36 |
Joe, did you see my post above about the pump info you requested?? Post# 34..
03-04-2021, 01:49 PM | #37 | |
03-04-2021, 02:04 PM | #38 |
Ok I found the melling #10295 it is a high pressure oil pump that puts out 10% higher than stock so thank you 1JEWLDSSRS and TheFlyingBananaSS.
03-04-2021, 03:21 PM | #39 |
Mystery solved?? I hope. You are welcome my friend!!! Glad we could help you out.. Good luck with everything!!
03-24-2021, 12:09 AM | #40 |
Drives: 2011 chevy camaro 2ss Join Date: Mar 2021
My 2011 camaro 2ss idles warm at 25psi-30psi bone stock... on the pedal.. 40-50psi..Hard on the pedal 50-60psi.
L99, how ever I use a range AFM disabler so I run v8 all the time. |
03-25-2021, 11:44 AM | #41 |
Thanks for the info. But what does your car rpm idle at?
01-11-2024, 03:18 AM | #42 |
Drives: 2011 Chevrolet Camaro SS L99 AT Join Date: Oct 2021
Old topic but still I haven’t found the answer, what oil pressure should be at hot idle (Vin J) ?
Few years ago I saw somewhere on YouTube an old official video from GM, where they said that if the pressure is less than 26 PSI at idle, then this may be the cause / or consequence of improper operation of the AFM... My 2011 SS L99 at hot idle at 250F show on gauge 15 psi, 240F = 18 psi, 230F 21 psi. Warm engine 26 psi, cruising at low speed 30 psi, cold start 50 psi. Using Range AFM disabler. I started to use Lucas Heavy Duty Oil Stabilizer and idling pressure increased +5 psi. /// I also replaced my oil pump to MELLING M365. Stock oil pump was 12710304 (but 12612289 and 12710304 are the same thing). I'm currently considering the MELLING M365HV as larger displacement pump - 20% Additional Volume Over Stock Oil Pump. Or MELLING 10355HV - High Volume and High Pressure +10 PSI Higher Pressure
2011 Chevy Camaro SS AT L99 / Stock / Daily Driver
1972 Plymouth Barracuda RB V8 3X2-barrel Holley R-4382A/R-4375A/R-4383A (Hamtramck) / Stock / Weekend Driver |
