10-25-2021, 04:29 PM | #43 |
Drives: Whipple'd Mustang S550 Join Date: Jun 2014
Thanks.
I ended up just doing the DOD/AFM/VVT delete kit/TSP cam install and leaving the oiling system alone. Caps out at 60 psi which is fine, seems to work normally. Interestingly enough, I recently worked on an LSA swapped SS, and even the LSA caps out at 55-60 psi (I am told it also has the oil psi relief in the pan). Currently working on a VVT/DOD delete on another one, and this one I removed the pan and did the relief delete and removed the L99's oil pump and replaced with an LS3 pump. Holds 43-45psi at idle (just like older GEN3 LS's). Still working towards getting out and tuning it, but will report back on OIL psi across the RPM range as I get that far.
'17 Whipple'd S550 Mustang, Stage 1 (750hp) kit, all stock otherwise less M/T ET Street Radials/VMS Rear Drag Pack Only. 643 RWHP (dynojet). 10.92@128, 1.59 60' (2800 ft corrected D/A). 91 Octane+Boostane Octane Booster.
Many other turbo LS/Ford Builds to date, see my YouTube channel YouTube Channel: https://www.youtube.com/channel/UCr7..._as=subscriber |
10-26-2021, 01:33 AM | #44 |
Drives: Mercedes Join Date: Oct 2021
thanks for clearing doubts about dod delete kit
The Global Associates Company offers B2B Lead Generation, Appointment Setting, Inside Sales Outsourcing, Data Solutions for companies globally.
Best Lead Generation Companies In India |
