12-25-2020, 12:09 PM | #43 |
USA-1
Here are some shorty vs longtubes dynos - https://www.hotrod.com/articles/headers-dyno-test/
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
12-25-2020, 12:30 PM | #44 |
Like said above, the first guy has lost his marbles and is very wrong, and 80 gain? There would have to be more to it than just the LT's for that. Mine stock exhaust with an axle back dyno'd at 331 and with the LT's and off road mids and an axle back dyno'd 365..
12-25-2020, 12:42 PM | #45 | |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
12-25-2020, 12:45 PM | #46 |
But what about cats? Do I need high flow cats with o2 extensions or run no cats and have it tuned to run with only the upstream o2's
12-25-2020, 03:06 PM | #47 |
I'm running "off road" mids, no cats. Had them tuned out, but that depends on if you need them for emissions where you are located. No measurable HP gain for the off road mids over the HF cats from what I have read on here.
12-26-2020, 08:26 AM | #48 |
USA-1
I'm running catless, and I did need o2 extensions. If you don't need cats I'd go with Speed Engineering longtubes, I've been running them for 4 years and they use the same 304 steel as Kooks and make the same power.
12-26-2020, 09:46 AM | #49 |
But are you running two o2 sensors or four? And if I run two o2 sensors do you know how much it will cost to get the tune done? Oh and where? And one more question, what type of exhaust will bolt directly to the headers to the tips.. Thanks
12-27-2020, 08:17 AM | #50 | |
Drives: 2010 Camaro 2SS Join Date: May 2016
If no then speed engineering headers with no cars will work and you will be not using the two sensors.You might also have a unburnt fuel smell at times. If having to pass emissions then Texas speed headers with high flow cats would probably give you what you want.Depending upon how strict the emission standards are. |
12-27-2020, 09:37 AM | #51 |
USA-1
Ok, so, honestly, I would get the longtubes and get an x-pipe and keep the stock mufflers. I have this setup and I think it's perfect, it sounds great at idle, awesome at WOT, and no drone on the highway. Axle back exhaust does nothing for you for power, so for me, the cost isn't worth it.
As far as tune, I got a tune from RDP Motorsports using their SCT X4 tuner with lifetime tunes. I paid $400 (4 years ago) and have gotten multiple new tunes for my new mods, it's a no brainer. https://www.rdpstore.com/p-6042-tune...tom-tunes.aspx
12-27-2020, 11:04 AM | #52 |
They don't do sniff test here in Texas only check for cel. So I don't think I actually need cats. But don't I need at least two o2 sensors for the pcm to run the air and fuel ratio? And when I bought the car it has no mufflers with an x crossover and 4" tips. It actually sounds pretty darn good I just think the headers will push it to far.
12-27-2020, 04:07 PM | #53 |
Drives: 2012 ls3 Join Date: Feb 2014
No cats long tube headers and no mufflers the tune eliminates the light. Been passing inspection for 4 or 5 years. This year they hit me for no mufflers.
12-27-2020, 05:52 PM | #54 |
But how does the pcm run in closed loop without o2 sensors?
12-27-2020, 08:48 PM | #55 |
USA-1
The tuner takes care of all that crap. I just did emissions recently and had no issues.
If you are already no mufflers, x-pipe, your car is gonna be LOUD with longtubes...
