08-07-2020, 12:25 PM | #15 | |
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
08-07-2020, 12:30 PM | #16 |
Drives: 2010 ss/rs 6 speed manual Join Date: Aug 2013
That is wrong. I know it’s wrong the front bolts to the oil pan on v8 motor bolt into the front cover. Op has ss so he has v8 he doesn’t need to remove the front cover to the timing chain. I just did this myself and didn’t remove it. The v6 motor you may have to do all that but not on the v8
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
08-07-2020, 12:33 PM | #17 |
Once you remove the cross member its as Easy as removing the bolts to the pan, removing oil cooler from side of pan, lifting the motor slightly so the pan can clear oil tube.
Heck even in your own picture you can see the front of pan And see the 2 bolts that go into the timing cover. Once those two bolts are out, rest of bolts and oil cooler done there’s nothing from the timing cover preventing the oil pan from coming out. Only reason to go as far as you did is for oil pump, cam, or timing chain changes. Which the op wasn’t asking about
08-07-2020, 12:36 PM | #18 | |
08-07-2020, 12:49 PM | #19 | |
08-07-2020, 01:00 PM | #20 |
Drives: ABM #93 Join Date: Oct 2018
It’s called the windage tray, and your right I’ve had a few ls engines apart and never had to pull the pickup tube to get the pan off. I just tore an Ly6 6.0 all the way apart 2 weeks ago with no problem removing the pan.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
08-07-2020, 01:24 PM | #21 |
I couldn’t find a better picture but here you can see the pickup tube still attached to the motor without the oil pan. It only bolts to the oil pump and a bolt that holds on that pan/windage tray you can see in this picture under the crank. If my pan was still off the car and I could get better pictures I’d gladly show you better detailed pictures. But my oil pan came right out of the car without pulling the timing chain cover.
08-07-2020, 01:27 PM | #22 |
Thank you I couldn’t remember that name off the top of my head for the life of me lol. It was like oh I know what it is but but I can’t remember! lol
08-07-2020, 01:40 PM | #23 |
ahh, I see. You are right. I was wrong. Yea, I think he could do all the work himself if he wanted to.
08-07-2020, 01:49 PM | #24 |
Drives: Camaro v6 rs 2014 Join Date: Jul 2018
hi
can someone tell me how to write a post? I am new here and I couldn't figure out how to write a post. the only thing I found is to reply to a post. I can a problem with my 2014 v6 Camaro and I would like to ask the community here. thank you |
08-07-2020, 02:37 PM | #25 |
There should be a 'New Thread' button on the upper left of the forum page that you are located in and want to post in. Click that button, then give your thread topic a name under 'Title' and create your post in the 'Message' box.
08-09-2020, 12:32 AM | #26 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Thanks guys for all your input. I Have a small welder and what I think I'll do is tack wield the flanges on and take it to a shop to have it professionally wieded.
08-09-2020, 03:04 PM | #27 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
On my 2012 I unbolted the steering rack and pushed it forward so the pan would drop enough to clear the pick up tube. I made my own cross over brace.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
08-09-2020, 04:45 PM | #28 | |
I remember you saying you moved the steering rack. I found it easier to loosen the two bolts for the motor mounts and jacking the motor up a tad and the pan came right out. There probably isn’t a wrong way to make the room I guess it just depends on what your most comfortable with.
