04-25-2021, 01:06 PM | #15 | |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
I will gladly post them. He seems like he wants to make a point, however which concerns me. He used to work w GPI products and no longer supplies them. Assuming he doesn't pull timing on it, it should make power. I researched these and seems they do make gains with modest bolt ons, adding any type of cam should be gravy. I just get pissed with the max effort guys, rah rah 'you won't make any power unless heads and stage 4'. I am not buying it. |
04-26-2021, 02:51 PM | #16 | |
Drives: 2000 Camaro SS, 1966 Mustang Join Date: Jan 2021
LS3 Block (427CI) Forged Manley 4.1" crank T-Rod modded LS3 intake (by me) Ported 821 heads (by me) TSP cam 243/255 .621/.619 111 LSA HP tuners pro (by me) https://www.smokingasphalt.com/ https://www.youtube.com/channel/UCR-...cEEQ4y_YaXMD6Q |
04-26-2021, 03:10 PM | #17 | |
Once cam is installed a run there. Then with the ported ls3 intake, likely while its on there. |
04-26-2021, 04:00 PM | #18 |
Awesome, that would definitely be an ideal test.
04-26-2021, 06:53 PM | #19 |
USA-1
I'm not sure the peak gains are where the manifold shines, but more across the whole powerband. I totally expect you to see good gains with it, BUT, are you doing a test where the only thing you are changing is the manifold?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
04-26-2021, 07:06 PM | #20 | |
Negative.. Vette guys claim it makes power with bolton's minus cam. I have a mild cam going in and was looking for additional power while waiting for the cam to come in(1 month). I found this intake which is similar to GPI's rod mod intake but also ported and the rods are smoothed out(essentially halfed) to smooth the airflow further. G8 guys and SS sedan crowd have used with good success on mild cams or boltons. Long story short, my tuner does not believe it will make any power and is offering free dyno after install. The cam is stated to make 35-40 whp and good under the entire curve with no loss down low. Any additional to the cam is good to me. The claimed throttle response is worth it alone, but will add torque and some whp. |
04-27-2021, 03:17 AM | #21 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
I picked up some good numbers with a ported rod mod over stock with a port matched throttle body. The fast is too expensive and doesn’t compete.
Stock mani: 450whp and 420tq Ported rod mod: 460whp and 436tq
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
04-27-2021, 05:37 AM | #22 | |
Decent gains.. what was the cam spec? Likely more aggressive than what I will be doing. What size was the throttle body? |
04-27-2021, 06:01 AM | #23 |
Nightfury cam and stock ported TB.
04-27-2021, 03:52 PM | #24 |
USA-1
Why such a mild cam? The GPI SS1 cam can get to 457 RWHP with supporting mods (not including ported heads) such as UDP and ported manifold...
I posted on here awhile back about gains on a FBO with the manifold and was told peak might be 5 hp...I honestly didn't feel much gain on mine, but i'm sure it's helping.
04-27-2021, 04:33 PM | #25 | |
Drives: 2012 Camaro SS Join Date: Dec 2019
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-27-2021, 04:36 PM | #26 |
USA-1
Right, that's why above my last post I said "I'm not sure the peak gains are where the manifold shines, but more across the whole powerband."
I think GPI said they saw some gains of 20 rwhp below peak on a cammed car...damn good if true.
04-28-2021, 03:44 AM | #27 |
If you look at my dyno graphs the stock mani only made 450 from 6200 to 6700.
The rod mod did it at 5700 and carried it past 7000. Good useable power.
04-28-2021, 08:14 AM | #28 | |
I also am looking for good characteristics, no down low loss and power everywhere. Cam is quoted to make 35 40 whp. I want it to be able to run auto x, circuit possibly. |
