03-02-2020, 07:46 PM | #1 |
Drives: 2012 Camaro SS Join Date: Dec 2019
F.a.s.t. vs rod mod/ported OEM intake
They are about the same price so looking which one would perform better on a NA build.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
03-02-2020, 07:53 PM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
How are they almost the same price? The F.A.S.T is almost a grand and the GPI modded one is $400 + shipping for a manifold. The GPI manifold has been shown to be a real winner for a street car. Other manifolds may make more on top but lose more down low. The GPI modded one makes decent gains across the board.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
03-02-2020, 07:55 PM | #3 |
Orange Krush II
03-02-2020, 07:57 PM | #4 |
For a bolt on/mildly cammed car I would say GPI Ported Rod Mod would be the best bet.
You really can't beat that stock manifold for under 6500 rpm. Once you start pushing over 6500 rpm it becomes a bottleneck.
03-02-2020, 07:58 PM | #5 | |
SomeguyK
More to come. |
03-02-2020, 08:01 PM | #6 | |
This is still cheaper than the fast
03-02-2020, 08:02 PM | #7 | |
03-03-2020, 05:34 AM | #8 |
Tri-County Camaro SWFL
If you Google Rick Crawford rod mod intake, go on some g8 forums and your questions will be answered. Theres even a dyno test between the RCR intake and a Fast 102.
03-22-2020, 09:59 PM | #9 |
Rod mod vs Fast 102
I purchased a new GM manifold, and sent it to GPI for Rodmod, porting, and heat shield. They also ported my throttle body. Torque is very good in mid range. On a Mustang dyno, Rwhp 445, Rwtq 437. If the car is used as a daily, the rodmod is the way to go. What percentage of your driving is above 5,000 rpm?
03-22-2020, 10:10 PM | #10 |
You'd be surprised with some of the guys in here!
04-25-2021, 08:07 AM | #11 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
I am having a RCR style intake installed soon. I am also adding a mild cam. I am having before and after dynos offered by my tuner. He doesn't think it will pick up anything. I have seen bolt on ls3 without cams benefiting, so I hope it will.
Mine is ported and has the radius rods installed. |
04-25-2021, 08:24 AM | #12 | |
04-25-2021, 08:29 AM | #13 |
Technically this isn't a Rick crawford, rather a T rod modded and ported ls3 mani. G8 guys had good success with them.
Did you dyno before and after with yours? Do you have a cam with it? I selected a mild cam and I am hoing the intake will add some hp and torque to even things out. My cam is 220/230 with 117 lsa. |
04-25-2021, 12:54 PM | #14 | |
