Old 05-18-2018, 01:16 PM   #29
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Originally Posted by DANACO View Post
The ONLY place in my 2018 Camaro Owner’s Manual that references the cabin filter is in the schedule that mentions the various filter part numbers. NO where else is it mentioned or listed anywhere !
I just pulled up the 2018 camaro OM and it mentions "filter" ... 69 times. First reference to the Passenger Compartment Air Filter is on page 192.
https://my.chevrolet.com/content/dam...ers-manual.pdf
Part number is on page 341.
Old 05-18-2018, 04:55 PM   #30
DANACO
DANACO's Avatar
Drives: 18 ZL1
When I get back to my little white rocket I’ll have another look in the OM
DANACO is offline   Reply With Quote
Old 05-19-2018, 02:48 PM   #31
Frank237
Frank237's Avatar
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS
There is a video on YouTube that shows removal/installation. I just watched it in order to get to my own mouse house. Can not believe the best some Engineer could come up with was to use a long screwdriver or flat pry bar....to PRY the hinge away from the mount! They couldn't add a couple of buttons or a lever, or a pin?
Any one have any idea WHERE the F'in INLET is for the CAF? I looked around, will crawl underneath when it stops raining. Thinking of putting some screening over the inlet to deny entry to the next rodent.
Back to rodent body retrieval duty..........
Frank237 is offline   Reply With Quote
Old 05-20-2018, 08:58 PM   #32
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Inlet is under your cowl...……….
Remove both wiper arms, then all push pins, about 10. cowl will lift off.
Once removed. move to pass side, you will see big black deflector panel held on by 2 more push pins. once removed, you will see inlet.
You asked!!!
=Bobby
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 05-20-2018, 11:39 PM   #33
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 ZL1, 2021 Corvette Convertible
You asked!!!
=Bobby
Yep, that’s exactly the process my friend used to install a screen over the inlet. He also filled up an area on the passenger side with silicone. I’ll clarify the exact area when I see him this week.
Old 05-21-2018, 03:31 PM   #34
Frank237
Frank237's Avatar
Monday update..... Bought a small, 9mm inspection scope, with a 3' lead. Snaked it in and there are fuzz balls and crap all over the place, in and around the heater fan. As well as two balls of maggots. So I have probably found the nest with dead babies and the parent. Car REALLY stinks today.
I thought I could maybe save myself the deductible by cleaning it myself but doesn't appear so. Access is just impossible without removing parts of the dash, etc. Off to the Dealer.
At least it doesn't appear they chewed any wires.
Old 05-21-2018, 03:33 PM   #35
Frank237
Frank237's Avatar
You asked!!!
=Bobby
Thanks....What do you use to remove the push pins? Putty knife? Or is there a special tool?
They are reusable?
I already have some galvanized, 1/8" mesh screening and some HD Caulk. To rig up something so this will not happen again.
Thanks again for the info!
Old 05-21-2018, 03:48 PM   #36
7WSM
7WSM's Avatar
Drives: 2017 ZL1 A10
That's nothing compared to the wiring harness that all the manufactures are using now. The wiring insulator is a soy based covering. I have seen my fair share of rodents getting in the engine compartment and doing major wiring damage.
7WSM is offline   Reply With Quote
Old 05-21-2018, 04:31 PM   #37
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
You can use a butter knife but much easier using the tools. Yes reuseable.
https://www.ebay.com/p/Automotive-Do...ool/1111815127
OR
https://www.harborfreight.com/nylon-...-pc-69668.html
They are reusable?
Old 05-21-2018, 04:51 PM   #38
ss_rob
Drives: SS
Originally Posted by wwiiavfan View Post
Yeah, looks pretty easy.
BTW, Rock Auto has the premium Delco filter for less than the standard.
Premium is on the way!
Part number?
ss_rob is offline   Reply With Quote
Old 05-22-2018, 06:43 AM   #39
wwiiavfan
Drives: 2017 1SS Hyper Blue
Originally Posted by ss_rob View Post
Part number?
CF 1184C
wwiiavfan is offline   Reply With Quote
Old 08-22-2020, 03:25 PM   #40
slvr162ss
Drives: 2016 2SS Convertible
My Attempt at a Rodent Screen
Live in the country and all kinds of crazy rodents - mice, chipmunks and red squirrels. Had a nest in the cabin air filter last winter so I decided to try and cover the air intake hole in the firewall with a screen. Was hoping to just zip tie some window screen around opening but not enough of a flange around the top edge of the firewall hole. Used a disposable aluminum cake pan. Cut the sides down and form fitted it into the opening. Fastened it in with some duct tape. I punched the holes on a bench before installing then opened them up some after install with a nail punch. Air flow seems ok. Recirculate mode has stronger air flow through vents but I think that's always the case. Critiques welcome.
slvr162ss is offline   Reply With Quote
Old 08-23-2020, 07:50 AM   #41
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I would have made the holes bigger, Seems like a lot of restriction there.
Old 08-23-2020, 08:32 AM   #42
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
A mouse can get through a small, 6-7 mm hole (about the diameter of a normal-sized pen) and a rat can get through a 20 mm hole.
I’d use a rigid perforated stainless sheet.
Your holes look too big, the material is too soft (thin aluminum is a mouse delicacy, ask me how I know) and there isn’t enough free open area (at least in my opinion).
