05-19-2022, 04:06 PM | #1 |
Drives: None Join Date: Apr 2022
Removed rear diffuser/splitter
Anyone completely removed, or cut the rear splitter/diffuser?
05-19-2022, 04:17 PM | #2 |
05-19-2022, 05:20 PM | #3 |
Drives: 1968 SS/RS, 2006 H2 2016 2SS White Join Date: Sep 2015
Why
2016 2SS White fully loaded
05-19-2022, 05:27 PM | #4 |
05-19-2022, 06:38 PM | #5 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
05-20-2022, 02:03 AM | #6 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
It also helps with aerodynamics...
05-20-2022, 05:31 AM | #7 |
Drives: 2017 2SS F1FTY Join Date: Feb 2020
2017 2SS F1FTY/HUD/Mag Ride/NPP/Nav/M6/Mishimoto catch can/BTR stage 2 Cam kit/GPI ported LT2 IM and 95mm TB/Roto Fab CAI/Kooks Long Tubes ceramic coated/Borla S Type NPP catback/AFE lowering springs/1LE wheels/OEM smoked tail lights/Diode Dynamics side markers/Uniden R7/3D Maxpider floor mats/Adams graphene ceramic coat
05-20-2022, 07:40 AM | #8 |
It does look good and it may also catch air under car at 150 mph so not a bad idea at all.
05-20-2022, 09:59 AM | #9 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Removing it causes turbulence under the car which can cause the vehicle to lift more at higher speeds Is that not correct?
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
05-20-2022, 10:34 AM | #10 |
05-20-2022, 11:05 AM | #11 | |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
Whatever floats your boat,, I say! I'll keep my diffuser, to, well, uh, diffuse!!! |
05-20-2022, 01:37 PM | #12 | |
I guess if you aren't on a turn course, it would be ok if all you do is go in a straight line. I just never seen a car with a parachute running Nuremberg or with no diffuser. Aerodynamics is a funny thing I guess
05-20-2022, 06:27 PM | #13 | |
05-20-2022, 07:18 PM | #14 |
Exactly what I mentioned in an above post. I wish I'd thought of that since I did go 149 on one pass with my 16ss 2650 Maggie. Dam, missed that boat. Plus on my street car I could run 4 tips like my C7. I'm in.
