03-29-2022, 11:43 PM | #1 |
Drives: 2013 ZL1 & 2012 2SS Join Date: Nov 2021
ZL1 Seems Slower Than SS
Hello, I have a 2012 2SS and a 2013 ZL1. You can see what build the 2SS has in my sig down below. ZL1 is bone stock. The ZL1 only has 17K miles on it.
Anyways I figure my 2SS cant be anymore than 450 HP and my ZL1 stock should be a lot more than that. When I drive the 2 the 2SS just seems to be a decent amount more powerful. IDK if its just me and its now the power is made between the 2. ZL1 makes smoother power vs the 2SS being more torquey? These cars are both newer to me. Any insight on how they should compare to each other would be helpful. I just thought the ZL1 would be a totally different monster. Maybe I had to high of expectations. Thanks in advance!
2013 Chevy Camaro ZL1 Yellow Completely Stock. Brand New To Me
2012 Chevy Camaro 2SS/RS, LS3, GPI SS1 Cam, GPI Cam Kit, LS9 Head Gasket, Upgraded Valley Cover, Upgraded Crank Bolt, Lifter Trays, CHE Trunnion Kit, BTR Platinum Valve Springs, GPI Hardened Push Rods, GPI Phase Limiter, Upgraded Lifters, Corsa Dual Exhaust, Cold Air Intake, Headers. |
03-30-2022, 02:20 AM | #2 |
it seems that either the butt dyno is off or the ZL-1 isnt making the power it should.the stopwatch doesnt lie,what does it say?
03-30-2022, 06:00 AM | #3 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
When my friend bought her ZL1, it felt slow. I put the HPTuners scanner on it. It was seeing 7 degrees of Knock retard and pulling a lot of timing. We changed the plugs and put some fresh fuel with octane booster in it. Flashed the maf curve back to stock, since it had a small adjustment from the PO having an intake on it, and it made a huge difference. Timing was 15degrees before and 21.5 after.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
03-30-2022, 06:03 AM | #4 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Converter and gears stock in the SS? Those will change how it hits
03-30-2022, 06:13 AM | #5 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
03-30-2022, 07:31 AM | #6 |
Is the SS louder than the ZL1? Noise can give the impression of speed.
03-30-2022, 08:14 AM | #7 |
Yea I hear what you are saying. I have a friend that has a 2014 ZL1 m6 Camaro, and when he goes for a ride in my modded 2011 SS he says it pulls a lot harder than his Zl1, and he'd rather ride in mine than take his out for a spin!! lol. Maybe it's just that the way the HP and TQ are applied between the 2 cars is the reason, plus mine is a lot louder than his, still stock. The fact that my stall lets me get way up into the power band where the ZL1's start coming on gives my car the feeling the same as his does up there in the mid range, plus tha fact I can wind mine out to 7400, and his drops off way below that makes mine feel stronger. Just a thought..
03-30-2022, 09:08 PM | #8 | ||||
03-30-2022, 09:10 PM | #9 |
Just confirmed it has stock converter and gears.
03-30-2022, 09:20 PM | #10 | ||
I drove the SS today since I had driven the ZL1 yesterday and it feels like a total difference driving the two. It’s frustrating.
03-30-2022, 10:22 PM | #11 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
Just make your SS a ZL1 killer. It’s fun.
03-30-2022, 10:26 PM | #12 |
Drives: 2013 1ss Join Date: Jul 2012
find a stretch of road and time a zero to 80 mph or so with each car. Supercharged cars typically do not have a powerband hit or feel to them. My torque curve is pretty flat from 2k to redline.
03-30-2022, 11:18 PM | #13 |
This will all change once you start doing similar mods to the ZL1. Your SS is modded and tuned to be a street monster at the top of its game for an NA car, while the ZL1 is running a stock tune which was set up for driveability so it didn't scare people away from the dealership.
Just a tune and pulley swap would totally change that ZL1, let alone all the other mods your SS has. I was always under the impression that a bolt on and cammed SS would easily hang with a stock ZL1? They are right around the same crank/rwhp, amirite?
03-30-2022, 11:56 PM | #14 | ||
For real!
Ya I guess everything that I was told is that the ZL1 should still be faster and more of a monster. But could have been bad info. When I bought the ZL1 I was hoping for more without having to Mod it. But I may want to now if thats the case. Just wanting to make sure there’s nothing wrong with it you know. I appreciate the help!
