03-07-2022, 01:56 PM | #1 |
"Lohla"
Need a trunk mounted meth tank. What do you recommend?
Hi folks. I've been running the reservoir approach and i'm tired of being out of meth all the time. What are you all doing for addressing this. I'm reluctant to switch for fear of getting a bad system but its time to make a move. Can't even make it through a rally without a couple different refills......
Thanks in advance! Jared
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
03-13-2022, 01:12 PM | #2 |
Drives: 2018 Camaro SS Join Date: Sep 2009
I went with the Prometh Universal 3 Gallon tank. WeaponsX has a nice one as well that mounts to the side, in front of the battery
03-13-2022, 01:27 PM | #3 |
I like how trunk setups avoid the elements. It seams beneficial to have the pump mounted horizontally too. I’ve seen pump failures that looked as if water had ran down the seam of the pump and seized the bearing. Keeping it dry in the trunk and horizontal seams to me like it at least removes that problem from the meth failure worries. I also like that if there was a leak the meth wouldn’t run into the electric motor. Who knows if it’s worthwhile
03-15-2022, 02:37 PM | #4 |
"Lohla"
NICE! Thank you! Thats a pretty slick install. I'd prefer it flush but thats not bad at all. I also hoped for 5 gallons but 3 is MUCH better than 1. Thanks again. I'll check this out.
