02-02-2022, 06:32 PM | #1 |
Drives: 2017 ZL1 Join Date: Aug 2020
Help me rebuild this to 750 whp
Planning to get started on the blown LT4 in the next few weeks. The shop that scoped it can't be sure, but think replacing the pistons and rods and honing the block may take care of it.
Car last dyno'd at 688 whp with a 9.1 lower, ported tb, rf, 45% ethanol tune, kooks, jam aux booster. Looking to shoot for 750whp with putting in a 32% cam and porting the factory blower. What else should I be looking at doing besides the upgraded oil pump in hitting that number and living a long and healthy life? Last edited by dbs1; 02-02-2022 at 09:05 PM. |
02-02-2022, 07:11 PM | #2 |
Save the money and buy a Maggie 2650 and sell your Lt4. Easy 750 and you still get money back on your 1740 blower. Go for it.
02-02-2022, 07:12 PM | #3 | |
02-02-2022, 07:19 PM | #4 |
NOT doing the Maggie, unless my son wants to go to that expense and go for 850whp and all the other items needed for that.
Already have kooks LT's and planning on a bigger tb and the big gulp. Last edited by dbs1; 02-02-2022 at 09:06 PM. |
02-03-2022, 01:52 AM | #5 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Cam Heads 103mm nw RF big gulp Ported blower Headers May need better low side to run more ethanol.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
02-03-2022, 02:03 AM | #6 |
Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
What are 750rwhp zl1s running 1/4?
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
02-03-2022, 05:47 AM | #7 |
Thank you Al Oppenheiser!
I would suspect an otherwise stock ZL1 with a) drivermod, b) trans tune, and c) rear drag pack outrun the 750hp cars which lack a, b, and c. But that's just me.
More useful answer: anywhere from high 8s to low 11s depending on the mods, driver and phase of the moon. Internal mods seem to give up to 0.4 improvement over otherwise unmodified internals. See also: https://www.camaro6.com/forums/showthread.php?t=427506 |
02-03-2022, 06:48 AM | #8 |
Probably running really low 10s. My SS with 2300 Maggie made over 750 and ran its best 10.00@139 before I rebuilt the motor and did the 2650 Magge.
02-03-2022, 08:18 AM | #9 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Curious to why limiting yourself to a 32% fuel lobe cam? Check out the BTR cams with their 38% lobe. Extra 6% for same price range. Is your car an A10 or M6? Auto go with BTR stage 2, and M6 you could do stage 2 or 3.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
02-03-2022, 08:23 AM | #10 |
LPE HPFP, 43% cam, +30 injectors if you plan on continuing to run Ethanol.
2016 NFG 1SS A8
02-03-2022, 09:08 AM | #11 | |
I have just a 32% cam and aux low side and I can run up to E40.
02-03-2022, 09:47 AM | #12 |
Dyno Show Queen LOL
Budget rebuild with 1200 hp capability
Polish Crank $250 Summit rods SUM-LS6125927 $566 Mahle Pistons 930228370 $900 comes with rings Rebalance Asm and ASM $2400 Ported heads $499.00 https://shop.katechengines.com/produ...er-heads-pair/ (if your only interested in 750 no need to spend the money on Inconel exh valves. Of course this is you doing disassembly and Reassembly mark the valves, buy new seals, spring compressor, and .660 lift spring retainer kit. .660 spring kit $229 -$450 (BTR or Comp) CHE 4920 trunnion upgrade $230 Push rods $100 Lifters Johnson, morel, or LS7 on that order (LS7 12499225) $180 to 200 LS trays 12595365 $9 to 11.00 Head Gaskets 12654622 $50 to 60 each Camshaft GT35 with 7.85 fuel lobe L210287515 $540.00 Camshaft I like the LPE stuff with the 42% lobe and there Big Bore pump or Ryne Cunningham has his stuff that based on same lobe. Cam phaser lock AMP Gen V lock out BTR cam phaser $50 (not a limiter) Cam bolt 12681018 $36.00 Timing Chain C7R by Hinson HMI-C7-RCHAIN $150 Water pump Gaskets 12657430 $3 or 4 bucks ea. LS Crank seal 12585673 $26.00 LT4 Exh gsk 12657093 $6.48 each Optional: Big bore pump L710166914 $1800 FIC plus 30 injectors $2200 If you do not do the LPE fuel parts get a cam with 38% and reuse the LT4 fuel parts
02-03-2022, 09:51 AM | #13 | |
Drives: 2018 ZLE (M6/hyper blue) Join Date: Nov 2015
The LS7 lifters arent that good...88958689 is the "upgrade" for the LS7 from GM. I didn't realize these would work in a LT4 though (although I also never looked into it). https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
02-03-2022, 10:50 AM | #14 |
I would advise building the setup to be able to run more then E40. Ideally I would want to get to E60. Nothing wrong with E40 but having to run that low means your fuel system is on edge of running out. I would want more window for error ideally...especially with a higher power build. Not everybody is on point with logging their car and making sure they are not running out of fuel. You and I are a exception compared to the average enthusiast.
2016 NFG 1SS A8
