Old 03-28-2022, 03:22 PM   #57
AMOR
AMOR's Avatar
Drives: Camaro
You can order while they still have em in stock.
AMOR is offline   Reply With Quote
Old 03-28-2022, 06:24 PM   #58
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
Originally Posted by AMOR View Post
1LE in fact takes 5 quarts from what I read, due to trans fluid also used for diff cooling, etc.
That's full system capacity. You can't get that fluid out unless you pressurize the system. When you drain, it's only ~3qts.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 07-27-2022, 10:56 AM   #59
asthmamax11
asthmamax11's Avatar
Thank you for remarking on this point
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 07-28-2022, 06:24 PM   #60
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Anyone need some, I have 4 quarts I'm not using.
carguy55 is online now   Reply With Quote
Old 06-06-2023, 11:56 AM   #61
Ruthlesszl1
Ruthlesszl1's Avatar
Drives: 20 ZL1 m6
How did it work for everyone I’m having third and fourth lockout on high rpm shifts with a triple disc clutch
Ruthlesszl1 is offline   Reply With Quote
Old 06-17-2023, 08:53 PM   #62
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Also curious on everyone's experience. I was getting some grinding on the track in 3-2 downshifts with ATF and I think it happened once with the Tremec fluid diluted some with the remaining ATF in the lines. Track temps per logging is a tad over 200F so the thicker fluid makes sense to me for track use.
wakespeak is offline   Reply With Quote
Old 06-19-2023, 04:29 PM   #63
MatthewAMEL
Well, I was so impressed with it in the 1LE, I almost immediately swapped it into the Blackwing. Over on the Blackwing forum, folks were complaining of the same issues as here and the consensus seems to be the HP-MTF is better.
Only problem now is catching it in stock at the TREMEC store.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
