09-24-2018, 12:10 AM | #1 |
Drives: ZL1 1LE Join Date: Aug 2018
Tire carrier - how to protect wheels?
Picking up an ATC trailer with tire carrier attachment. Interested in any thoughts about perhaps wrapping the metal bar that goes through wheels so they aren’t damaged in transit? Thanks
09-24-2018, 05:32 AM | #2 |
That's an awesome trailer. I'm thinking 4 wheels w/ tires would stand up pretty tight and not move too much. Maybe tape some microfiber towels on where the wheels are.
09-24-2018, 05:48 AM | #3 |
Drives: 19 ZL1 "ordererd", 06 silverado Join Date: Aug 2018
Is there a way to use some ratchet straps to hold the tires down? The bar looks like you cant wrap it because of the groove it slides in, or does it have enough room to wrap it and slide it threw? What about using like a pool noodle or foam insulation tape?
09-24-2018, 11:26 AM | #4 |
Drives: Tracks: 18' ZL1 1LE Join Date: Mar 2018
Foam pipes.
18' ZL1 1LE Red Hot track toy
Castrol SRF Ported TB/Rotofab dry intake AWE Track w/PLP APR GTC300 wing / Singular Endplates ASC Splitter / PA tunnels MFR Engineering Custom Diffuser Race Louvers Fender Vents APEX SM10 & ARC8 For sale: 2018 OEM ZL1 1LE Wing 12' Nissan GT-R SOLD |
09-24-2018, 11:42 AM | #5 |
Who Needs to KNOW?
See if PVC pipe will fit over the bar AND fits inside hub of the wheels.
Overwise, remote bar, install "hood" over the rack with Jeep hood type hold downs or similar latching mechanism. Few pluses, no need to feed bar through center.. downside, OD of tires need to be fairly similar to make up space with some pool noodles or similar.
ing for grip.
09-24-2018, 12:45 PM | #6 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
09-24-2018, 03:34 PM | #7 |
Drives: 2017 2lt rs Join Date: May 2017
Foam pipe insulation - home depot
09-24-2018, 06:48 PM | #8 |
Thank you Al Oppenheiser!
pool noodle might work too.
09-24-2018, 07:03 PM | #9 |
nice trailer...it appears you can use a ratchet strap up and over each tire to hold an individual tire in place or use a single ratchet strap through the centers of the wheels to hold the grouping far left or far right. You don't need to worry about any foam padding or pool noodle stuff. The center bar is loosely there and only a fail safe.
09-25-2018, 08:46 AM | #10 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Rock guard in the plans also?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
09-25-2018, 09:01 AM | #11 |
