02-16-2020, 04:12 AM | #15 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Very well done.
Do you have a pic of the door switch connection? Where did you tab the power?
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
02-16-2020, 09:10 AM | #16 | |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
If you look at the picture on the 4th post, I highlighted where I tapped into the light circuit. Very simple. This circuit controls the dome lights and is actuated by the doors or round knob on the dash. The black wire going the the pink connector is ground, and the red going to the grey is switched 12V. If you zoom in you can see which location to use on each connector. I didn't even need to remove any connections or cut any wires, just pushed the pins I attached at the end of my wires between the metal contacts and plastic in each connector. No need to add any door switches or run wires to the doors. The only cutting to an existing part of the car was the rectangular hole under the dash for the rocker switch. |
