08-03-2016, 08:41 PM | #43 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
I got my car back with system installed. It is very impressive! Very clean install. Here are some pics of the system, 2 Diamond Shallows Series 12" subwoofers and a Diamond amp (I will edit this for the model number).
Amp was mounted nicely on a carpet wrapped platform. The platform was mounted using some existing screws. The existing screw used to mount the amp is on the bottom right A circuit breaker was installed by the battery and heavy cable ran to the amp
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
08-03-2016, 08:46 PM | #44 |
on to the line output converter
08-03-2016, 08:50 PM | #45 |
Screwed down nicely
back of amp Diamond Shallow Series
08-03-2016, 08:59 PM | #46 |
Back of the box. I was impressed with the woodwork. The box is not mounted down and is removable. In fact, installer said everything can be removed and no one will knwo it was ever there. Clean!
The subwoofer volume control is on the lower dash driver's side by my left knee. It defintely has the boom even with the shallow series subs. It sounds great just having them up loud enough to be like rear speakers. I had a BIG smile on when I kicked on the 21 Pilots song "Heathens"
08-03-2016, 11:48 PM | #47 | |
Drives: 2016 1LT Black Beauty Join Date: Jun 2016
08-04-2016, 10:12 AM | #48 | |
08-04-2016, 10:23 PM | #49 |
Drives: 2016 Camaro 2.0t Join Date: Jun 2016
Good write up, I just installed mine yesterday using this write up. Worked fine for one day, but I blew the power fuse on my amp.
02-09-2017, 09:07 PM | #50 | |
Drives: 2014 Camaro 1LS, 2016 Camaro 1LT Join Date: Dec 2016
02-19-2020, 08:18 PM | #51 | |
Drives: 1lt Join Date: Feb 2018
03-06-2020, 02:03 PM | #52 |
Drives: 19 Chevy Camaro LTa Join Date: Apr 2019
I just did an install with a loc on my non Bose camaro and I tapped into the back rear speakers only. Works fine. Has plenty of bass. Only issue I’m having is eliminating the ANC mic’s.
