08-19-2019, 06:39 PM | #1 |
Drives: ZL1 1LE Join Date: Apr 2019
widest tire wheel combo 19 and 20" ZL1 1LE
ok if this has been answered on a 1LE please direct me to the post, I've seen a couple but most are SS or ZL1 I know we have a little more clearance because of the DSSV.
Im going full custom wheels so any size and offset is available. Thanks |
08-19-2019, 07:07 PM | #2 |
Drives: ZL1 Join Date: Jul 2017
We fit a 355 V720 ACR tire on the back of the stock wheels on our ZLE. Required some "finessing" to get them to work.
08-19-2019, 07:17 PM | #3 |
What in your opinion would be the largest setup for 20", I'm glad the the OE wheels fit a 355 as those will be my track setup and want 20's for the street for more visual stance
08-20-2019, 01:15 AM | #4 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Aug 2019
Did you go wider up front? It would seem like going wider in the rear and not the front could cause handling changes (see understeer). Did you have to make any suspension changes to counteract any extra rear traction vs front (swaybar adjustment)?
08-20-2019, 02:46 AM | #5 | |
Car handles fine with 305/355 combo. No suspension changes. Had to add adjustable toe rod arms in the back to get enough camber to tuck the tires under the fender. |
08-20-2019, 06:44 PM | #6 | |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
08-21-2019, 10:39 AM | #7 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I’ll be trying a 325/30/20. I’m a little nervous as there might be a little poke with the off set on the new wheels. I think it’ll look great but concerned about the upward wheel
travel. |
