01-05-2019, 06:39 AM | #15 | |
Dyno Show Queen LOL
I'm cutting today anyhow..
01-05-2019, 11:29 AM | #16 |
Drives: 2018 ZL1 1998 SS 1992 Typhoon Join Date: Nov 2015
Lingenfelter made some kind of carbon fiber piece, they posted it on their IG yesterday. Sorry can't post the picture while at work.
01-06-2019, 08:21 AM | #17 |
Dyno Show Queen LOL
Yes I saw that originally.. Brandon from LPE says that they are out of stock for the mean time, LPE and Brandon have been very helpful guiding my build. I was going to try to make something similar or combo of what redine did and not make as big of a cut..
FYI I just noticed that Edelbrock left provisions for port injection on the runners lol..
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 01-12-2019 at 11:41 AM. |
01-06-2019, 07:33 PM | #18 |
Dyno Show Queen LOL
Not much progress..I had to work this weekend and wife got a flat tire on Saturday just when I started to work on the car. I had to take her a spare drag radial to get her to discount tire.. One cool thing is that I bought her 295 30 20 kumho sq setup they came w 10/32 and measured 8/32 they replaced the tire for free the manufacturer has road hazard the 1st 2/32 of tread for free.
I was able to find a roller bracket at work that mated perfectly to the sensor. I also took off those nasty 1/8 fuel lines Edelbrock had attached to the blower for vacuum lines. I used a longer bolt through the thermostat housing to attach the sensor. I was able to reuse the vacuum lines but on the longest line I picked up some hard vacuum line that worked perfect with the 90 degree boots on the OEM supercharger. (So I used 2 lines and boots from the other hard line of the oem). The extension came in so so the Tmap is taken care of. I got it off Amazon from Michigan' Motorsports there on Ebay to. Apparently it's a Ford turbo extension lol. See pic.. All I have to do is mount the reservoir I'll weld the bracket i made to the stock Edelbrock bracket at work tomorrow. I got it and the reservoir from Edelbrock it came from a dodge kit. I believe it's the same one ADM uses now his early style had hoses out the sides this has one in the bottom now. If your not handy just get the kit from him. *I'm test fitting pic is for reference... I'm not sure if I'll have room for my catch can in same area as the reservoir now. On another note plenty of room to get to the PCV valve without lifting blower or crushing the line..
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 01-06-2019 at 09:34 PM. |
01-06-2019, 09:07 PM | #19 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
I wish I knew wtf you’re talking about half the time !!!
You seem like you could do this with your eyes closed !!! I can barley change my own oil and put air in my tires. Jesus !!
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
01-06-2019, 09:55 PM | #20 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
01-07-2019, 06:49 PM | #21 | |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
for possible thread jack but I just wanted to let you know that Katech just posted this preliminary build with e85 on what looks like a crate engine LT5 for hot rodders and marine application.
I'm anxiously awaiting daily updates to your build.
Swift....Silent....Deadly
01-08-2019, 01:01 PM | #22 |
Dyno Show Queen LOL
Weld and bracket turned out good!
01-10-2019, 08:35 PM | #23 |
Dyno Show Queen LOL
Finally! got the reservoir and hose routing finished.. I made use of the factory hoses although to short since the 2650 is taller a combination of Gates premolded hoses did the trick along with two 5/8 to 3/4 heater hose couplers. The hose that comes off the intercooler pump is 3/4 yet the hose narrows to 5/8 for the oem blower manifold in other words, tapered down. The other hose is 5/8 all the way but the 2650 manifold is 3/4 and so is the reservoir. I made it look as close as stock as possible kept it away from the pulleys and out of the way for the filter box.
Parts used to mount the reservoir and mate to stock intercooler hoses. Gates 19839 premolded heater hose Gates 28479 premolded heater hose 2 5/8 to 3/4 coupler 2 24mm constant tension spring hose clamps 6 26mm constant tension spring hose clamps Edelbrock reservoir* Coolant cap C6 vette This car will be running tomorrow...
01-10-2019, 09:56 PM | #24 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Looking good! Thanks for the updates. Can't wait to see the results once it's finished.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
01-12-2019, 06:48 PM | #25 |
Dyno Show Queen LOL
1st startup... now schedule a tune..
https://youtu.be/O46IR6vIrdA I was wondering should I do the DSX pump now before the tune or during the cam install. I was thinking later just because we could see what it would do on a stock fuel system but anyone that has gone to the trouble to do, pulleys, exchangers, porting, TB, and meth on the OEM supercharger most likely would of installed an aux pump. Also anyone that bought this blower and didn't want to do a cam but wanted max results would install an aux pump.
01-13-2019, 04:18 AM | #26 |
Drives: 4 wheels and a motor Join Date: Feb 2017
I would say that logic is sound.
Low side fuel pump to maximize the gains of a bolt on car and get the most possible out of the blower before fuel becomes a issue. I'm hoping the 2650 turns out to be the sweet spot for blowers on a otherwise stock zl1. |
01-13-2019, 07:31 AM | #27 |
Drives: 2017 ZL1 Join Date: Mar 2014
The DSX fuel pump is only $1000. Most know (or soon discover) that the fuel system is the Achilles heel of these cars. Remove that hurdle now and proceed to share with us your findings. And thank you!
01-13-2019, 08:10 AM | #28 |
Drives: 2017 Hyper Blue ZL1 Convertible Join Date: Jun 2017
I’m kind of confused. With your Edelbrock supercharger are you not able to use your factory hood without modification?
Thread Tools | |
