12-01-2014, 11:12 AM | #1 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
2014 V6 manual shift knob?
I did a search and nothing really came up except some old threads, and the shifter design supposedly changed after 2012, if I recall.
I want to replace the black plastic shift knob with a solid white ball, kind of like the Hurst ball, but I don't want to replace the entire shifter assembly, just the knob. Can anyone tell/show me what they've done, and recommend any products? |
12-01-2014, 11:19 AM | #2 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
Try MGW or TWM if you want a great shift knob that will fit on the stock application.
Personally, I replaced the stocker with a Barton, and the knob with an 8 Ball from House O' Speed
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
12-01-2014, 11:21 AM | #3 | |
Drives: 2014 Camaro 1SS/RS M6 Join Date: Dec 2011
12-01-2014, 11:28 AM | #4 |
I'm pretty sure that the factory OEM sticks for all 5th gen models do not have threads.
So did you just juryrig it and get lucky? Or did you happen to have an aftermarket shifter?
12-01-2014, 11:29 AM | #5 |
Sources cited:
https://www.speeddawg.com/shifter-thread-sizes
12-01-2014, 01:12 PM | #6 |
The V6 manual shifter is a different assembly from the V8/SS manual shifters, is it not? (they're two different transmissions)
12-01-2014, 01:25 PM | #7 |
The gritos pollo!!!
Same shifter and linkage. Different trans
Yup still no threads on the stock unit
______
If you don't stop how can they give you a ticket?-The Big Tuna___ '12 1Ls Camaro; Slp loud mouth I|maganflow x-pipe|Injen long ram intake|brembo brake upgrade| russell s.s. lines|2LT polished 19's|billet 5mm spacers|tinted tail lights&markers|pdmi|billet c. can| '13 Avenger R/T '77 T/A 6.6;, draining my wallet. |
12-01-2014, 01:38 PM | #8 |
thanks for the confirm Vroom,
So, Op- to answer your question, the stick has the same non threaded notch to put the knob on, even though the shifter assembly itself is different. I think what 2014camaro did was put an undersized threaded shift knob on an oversized non threaded shifter, which probably mashed up the threading in the knob a bit, but if it works and looks good, why not?
12-01-2014, 01:47 PM | #9 | |
If the stick is unthreaded, then I'll probably need an adapter. |
12-01-2014, 02:26 PM | #10 |
Both MGW and TWM sell shift knobs with the correct adapter, or made for this application
