05-02-2021, 01:00 PM | #43 | |
Drives: 2017 Camaro 2SS Join Date: Mar 2019
The nuts are smaller in diameter for sure and splined, they come with a socket. I don't know if it would be possible for the factory nuts to fit in the holes on the M017s...
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon |
05-02-2021, 05:28 PM | #44 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
MRR sends lugs with the wheels. They don't have seats for the OEM acorn. I use MRR for AutoX, I would never use them for track and I have a set of lugs just for them. If you use the correct lugs, they hold 140ft-lbs just fine.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
05-31-2021, 10:56 AM | #45 | |
Drives: 2018 Chevy Camaro ss 1LE Join Date: May 2020
I know now I need new lugs I put my own wheels back for now, am going to buy the proper lugs when I return to Florida I just think the distributor that sold me wheels should have sold me the correct lugs, needed |
05-31-2021, 10:59 AM | #46 | |
Why would you not use them for track days? |
05-31-2021, 12:52 PM | #47 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Mrr<Apex...
2017 1LE Hyper Blue
06-29-2021, 09:51 PM | #48 | |
Thanks for the recommendation They fit great |
11-09-2021, 01:22 PM | #49 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
So for MRR M017s, correct torque with their (MRR) lug nuts is 140? I've read different things, 140, 100, 110 . . .
11-09-2021, 01:34 PM | #50 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Gorilla Lugs
I would use the EXTENDED gorilla Lug nuts as they engage an additional 3-4 threads. Below is picture of standard gorilla lug nuts and extended gorilla lug nuts. If you have a 5MM spacer or less you can use the extended lugnuts instead of using extended studs.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
11-09-2021, 05:56 PM | #51 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
The torque is determined by the stud size, the loads on the wheels, and other stuff unrelated to the actual wheels and lug nuts. The correct torque value with dry threads is always the GM spec of 140lb/ft.
Matt Miller
2020 SS 1LE |
11-09-2021, 08:53 PM | #52 |
11-11-2021, 05:08 PM | #53 | |
Drives: Duramax, 2018 Camaro SS 1LE Join Date: Nov 2020
If it ain't buckin, chirpin & makin all kinds of bad noises.... then I ain't happy!
