Old 02-10-2021, 08:40 AM   #15
EricFormula350
Drives: 2020 Camaro 2SS
Originally Posted by mikey522 View Post
how did you get it tucked in on the back side?
Just give it a little nudge and it will fall into place.
2020 Camaro 2SS A10 - Garnet Red/Kalahari, LT2 Intake, RotoFab CAI, Velossa Tech Intake Snorkel, JLT Catch Can, IKON Motorsports Rear Diffuser, MBRP Axle Back Exhaust, Anderson Composites Carbon Fiber Decklid, 1LE Splitter
EricFormula350 is offline   Reply With Quote
Old 02-10-2021, 08:42 AM   #16
EricFormula350
Originally Posted by dethzombi View Post
Reviving this thread to ask: did you have to do anything to get it to fit? Any modifications at all (other than the LT2 manifold)? Also, is there anything else you have like a coil relocation kit? The engine bay just looks overall very clean.
Only thing I did after installing the cover was cut a small square portion of the underside of the hood out where it would rest against the front top of the cover. Other than that, everything was fine. I have been looking to get the Katech valve covers and coil relocation kit.
Old 02-10-2021, 08:45 AM   #17
EricFormula350
Originally Posted by appleman22 View Post
looks good, hope your tuned for the lt2 manifold. Guys are running lean up top without the proper tune
Sure didnt.
Old 02-10-2021, 01:29 PM   #18
dethzombi
dethzombi's Avatar
Drives: 17 Camaro SS Red Hot
Would you be able to post a picture of what you mean? Really wanna go this route but I also don't want to cut a huge portion of my hood.
dethzombi is offline   Reply With Quote
Old 02-11-2021, 08:20 PM   #19
EricFormula350
Its cut right in front of the heat extractor.
Old 02-11-2021, 09:01 PM   #20
Aww, it looks pretty bare... you're planning to paint the raw metal and install some giant grommet or rubber seal around the hole, right?
Old 02-12-2021, 07:33 PM   #21
EricFormula350
Lol no. The insulation was put back over it so you don't even notice. Plus I have an AC ZL1 hood on order so I'm not too concerned with the stock hood.
Old 03-13-2021, 04:17 PM   #22
saltine1130
Drives: Chevrolet Camaro, Jeep Cherokee
Was looking at doing this but not if I have to cut the hood :/ Maybe my 2020 hood with the center vents would fit better? any one try this with '19+? Also, found this for those of you that don't want "Corvette" on your motor lol
https://wildhammermotorsports.com/20...agmotorsports/
saltine1130 is offline   Reply With Quote
Old 05-01-2021, 08:29 PM   #23
sage85z28
sage85z28's Avatar
Drives: 2017 1SS cruiser/ 1985 Z28 racecar
What extension harness did you use?
17 SS 2” ARH headers, high flow cats, and 3”X pipe into NPP, Katech ported 95 mm TB, LT2 IM, roto fab, DSX FF, Katech 160* BMR motor mounts, ATI damper, 493 RWHP
https://youtu.be/E-MDIyLtV48
sage85z28 is offline   Reply With Quote
Old 05-02-2021, 06:50 AM   #24
6spdhyperblue
Drives: 6th gen
How much clearance did you need on the 2020?
Any chance denting it in a bit would work?
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 05-20-2021, 03:06 PM   #25
EricFormula350
No other modifications for the cover. Just give it a nudge towards the back and it will fall into place under the cowl. No coil relocation kit. Thank you.
Old 05-20-2021, 03:08 PM   #26
EricFormula350
I am sure you could but for me it was just too close. I could close the hood without any modifications but it felt like it was pressing against the intake so thats why I cut it. Now I have the AC ZL1 hood with no issues.
Old 05-20-2021, 03:08 PM   #27
EricFormula350
The one that GPI sent along with the manifold.
Old 05-20-2021, 03:10 PM   #28
EricFormula350
This is a 2020 hood.
