Old 04-13-2018, 11:27 AM   #15
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Originally Posted by rjacobs View Post
Amsoil and WIX are NOT The same....
Amsoil is one filter.... WIX is another.
And that site you posted is garbage LOL... Its a shill site if I have ever seen one. "BUY NOW BUY NOW BUY NOW"
Only oil site I trust is BITOG.
WIX builds A TON of the OEM filters. They are regarded as being pretty good while being cheap.
Bob Is The Oil Guy is the one and only site to get your Oil and Filter information you need. It is all right there for you reading pleasure.
dmcmahan60 is offline   Reply With Quote
Old 04-13-2018, 11:35 AM   #16
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
The PF64 is NOT exclusive to the ZL1 or LT4 for that matter.... It is NOT designed for anything special as far as the LT4 goes.
Im not sure why the Corvette is not on this list because it uses the PF64 as well....
It is designated to be used on the LT4 engine by GM. That is my point. Not unusual for filters to have more than one application.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 04-13-2018, 11:35 AM   #17
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Originally Posted by SJFGTO View Post
Just curious. You don't think the filter that GM's engineers selected for this engine is "good", you may switch to K&N with no objective data that it is any better or any good at all, and your research is taking an internet poll on what filters are better than GM's specific designation?
K&N oil filters are garbage. You start poking around and you'll find stories of them sticking to the engine (even when properly installed) and then that little pot metal nut on the end (that is the ONLY thing you can grab it by), rounds off and then comes apart like the recycled old Frigidaire emblem metal that it is, and you have to employ harsh methods to remove the old filter. Hammer and chisel, unless you can get some kind of strap wrench on it, and even then don't count on anything more than the filter body deforming. And, yes, I have seen this first hand. Whee.
And, K&N air filters let more dirt into your engine than an OEM filter does, so those are just swell, too.
Emoto is offline   Reply With Quote
Old 04-13-2018, 01:22 PM   #18
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
anyone overthinking which oil filter to use...if my motor blows up, I want a PF-64 in place. Otherwise, GM has reason to deny a warranty claim. This makes the PF-64 the best & ONLY choice.
Old 04-13-2018, 01:37 PM   #19
Emoto
Sure, why not?
Emoto's Avatar
I'm with you.
Is there a consensus on where the best place to get them is, price-wise?
Old 04-13-2018, 01:55 PM   #20
Stephen12ZL1
Drives: '21 ZLE A10
Originally Posted by Emoto View Post
I'm with you.
yes, Amazon for sure.
Old 04-13-2018, 01:58 PM   #21
waterman
waterman's Avatar
Drives: Grandad's C2 L89
2018 ZL1 1LE sw/PDR
Old 04-13-2018, 03:22 PM   #22
itsadryheat79
itsadryheat79's Avatar
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z
Send a message via Yahoo to itsadryheat79
If you want to know how a filter compares - cut them open.
I would not take some ones intenet word - Trust but VERIFY.
Snake oil aside!
WIX makes a great filter and after looking at all the others I personally will use WIX or ACDELCO.
PF64 is recommended for the V8 Camaros from the factory.
It has the Anti-Drain Back valve - If you leave it sit for extended periods you need the Anti-Drain Back Valve.
In November of 2017 WIX specified 57060 for all 2010 - 2018 V8 Camaros.
They recently updated the 2016 -2018 Camaro to specify instead WIX WL10290. I have yet to find one and cut it apart.
According to the WIX site the By-Pass Valve Setting- PSI went from 12 PSI to 22 PSI.
Want the exact same thing as 57060 but cheaper - The "WHITE LABLE" WIX sold as PRO-TEC 115
- Search O Reilly's web site for 115MP $32 for a case of 12 = $2.67 per.
Yes its compatible (yes it has the drain back valve)- cut one open and compare lots of folks have.
I used this in 2 2010 NA Camaros and a 2012 ZL1 - driving and light tracking each car over 70K miles no issue.
I buy in bulk and just bought PF64 in March from Rock Auto - They have them in a case of 10 including shipping was $4.00 each
At this price point any cheaper than 4$ is just silly. Add to that the fact WIX changed their specification makes me wonder.
I use these PRO-TEC Filters at $32 per case for the following. - Never had an issue and not under warrantee
WIX 57060 = PRO-TEC 115 - LS motors
WIX 51060 = PRO-TEC 162 - BB motors
WIX 51069 = PRO-TEC 102 - SB motors
- Buttons and Skulls -
miss my annimated signature.
itsadryheat79 is offline   Reply With Quote
Old 04-13-2018, 03:48 PM   #23
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
http://sandyblogs.com/techlink/?p=7627
And the PF63E......
http://sandyblogs.com/techlink/?p=4518
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 04-13-2018, 05:15 PM   #24
itsadryheat79
Originally Posted by gblaue View Post
Thanks! - Appreciate the added info on the PSI change!!
Old 04-13-2018, 05:33 PM   #25
gblaue
gblaue's Avatar
Ditto
Old 04-14-2018, 05:23 PM   #26
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
I was hoping to not a have to trust a $4 filter for a $65,000 car
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 04-15-2018, 05:53 PM   #27
enzia35
Drives: '16 Garnet Red 1SS
GM is betting their $65,000 car and its associated warranty on that AC Delco PF64.
'16 Camaro 1SS
'18 Miata GT
Old 05-08-2021, 03:45 PM   #28
Buckwheat
Buckwheat's Avatar
Drives: 2021 Camaro ZL1
PF 64 oil filter for me
Buckwheat is offline   Reply With Quote
