Old 01-03-2017, 12:38 AM   #1
1LE801
"Lohla"
1LE801's Avatar
Drives: 2016 1SS A8 :"Lohla"
584 WHP 657 WTQ / now comes the Heads/Cam
Well my first winter with the car under a cover proved to be too much idle time for my mind so we went ahead and pulled the trigger on round 2 for the mods. JDP will be swapping out the heads and cam as well as addressing fuel needs and AFM deletion. I'm very curious to see what happens to compression and boost with these mods. We're at 10 lbs and stock compression so I wouldn't mind those numbers being a tad lower. We're adding HP Tuners nGauge and a wideband gauge to complete the data collection process as well.
Thanks for all the insight, my fellow forum friends. I'll keep you posted.
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
1LE801 is offline   Reply With Quote
Old 01-03-2017, 12:57 AM   #2
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
Looking forward to your results.
Sent from my SM-G920V using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 01-03-2017, 06:09 AM   #3
1LE801
"Lohla"
1LE801's Avatar
I shouldn't have to leave you in suspense as long as the Supercharger portion of the build did. Goes in Feb sometime and I'm hoping for 1-2 weeks.
Old 01-03-2017, 06:19 PM   #4
aka Reckless
aka Reckless's Avatar
Drives: 2016 2SS Camaro
Why is your compression going to change?
aka Reckless is offline   Reply With Quote
Old 01-03-2017, 10:14 PM   #5
1LE801
"Lohla"
1LE801's Avatar
Wishful thinking that head work could lower it if only slightly....
Old 01-03-2017, 10:22 PM   #6
aka Reckless
Only if the chambers are enlarged, and it wouldn't be much. It'll likely stay the same. I will be doing the "drop in" forged pistons and cam swap first. Then FI later. Fueling issues are my main concern.
Old 01-03-2017, 10:29 PM   #7
1LE801
"Lohla"
1LE801's Avatar
I don't blame you. Were addressing fuel for sure. We'll be using the LT4 high pressure pump and injectors.
Old 01-05-2017, 08:38 AM   #8
PRAY
PRAY's Avatar
Drives: 2016 2SS
Your cam will effectively lower your compression as well. If your SCR stays the same your DCR could change as much as .5 depending on the size of your cam. It is all dictated by the closing point of your intake valve. But with VVT it is always moving. Better flowing heads will also lower your boost which will put less stress on your motor. You will have to pulley way down after your H/C to get back to 10lbs of boost.
Old 01-05-2017, 11:32 PM   #9
1LE801
"Lohla"
1LE801's Avatar
Not dead set on 10 lbs. if it makes about 700 Wheel, I'll be good. Thanks for the info. I can't wait to get the work going.
Old 01-06-2017, 08:53 PM   #10
JFM-jr
JFM-jr's Avatar
Stock rotater?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 01-06-2017, 09:58 PM   #11
1LE801
"Lohla"
1LE801's Avatar
Originally Posted by JFM-jr View Post
Stock rotater?
Yes. LT1 bottom.
Old 02-16-2017, 12:08 AM   #12
1LE801
"Lohla"
1LE801's Avatar
Dropped off my baby today. The anticipation is killing me and I haven't I even made it a day yet. I'm really looking forward to the end result after having seen the gameplan, otherwise known as a parts list. It was nice to see a bunch of late model GMs.
I'll keep this thread updated as we go along. Stay tuned!
Old 02-16-2017, 06:47 AM   #13
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Better start saving for some wider wheels and tires if you don't already have them lol. I saw meth injection in your description. This car should easily exceed 700.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 02-16-2017, 08:36 AM   #14
1LE801
"Lohla"
1LE801's Avatar
I've got 315 Contis in back now but we're gonna yank them and put ET Streets on. They'll be 305/35/20. I'm worried they still won't hook though because of the sidewall. I'll let you know how good/bad they are. I'll have a similar set-up to you when I get it back. We are gonna try the stock injectors with all the other LT4 stuff. Jordan has made 780 Wheel on a 416 build with the same fuel set-up so we'll see what happens.
6th gen, heads cam, lt1, magnuson heartbeat
