08-04-2016, 04:51 PM | #15 |
Drives: 2016 Summit White 2SS (Auto) Loaded Join Date: Jul 2016
Hmmmm first time to the track with new combo, I'm gonna guess 11.23 @ 125 mph
08-06-2016, 09:51 AM | #16 |
Drives: 2016 Camaro 2SS, 2006 corvette Join Date: Mar 2016
We have a similar altitude at my local track (El Paso, TX) and I ran against a LMR 650 package C7 Corvette (ECS supercharged). He ran 12.0 at 126 but he was running a manual transmission. With the A8, I think you can run a 11.4 with a good tire out back. If not, it will be spin city lol.
08-07-2016, 07:29 AM | #17 |
I'm in at 10.85@129
08-09-2016, 09:45 AM | #18 |
"Lohla"
Traction will be addressed for sure. Man, I hope you're all right. If I run 11s my first time out, I'll be happy. Low 11s that is (fingers crossed)
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
08-12-2016, 06:26 AM | #19 | |
Drives: '14 Z51 C7 SC'd, '14 S4, '15 SQ5 Join Date: Jul 2015
There are some pushing it higher than there but the safe limit based on a ton of cars out on the roads is 700rwhp. If the fuel system is the same as the C7 then it does get touchy near 580rwhp without meth. What will work on a dyno and what will make it live are two different things. For the cost, ease, and additional benefits of meth its cheap insurance. |
08-16-2016, 09:17 AM | #20 | |
"Lohla"
08-16-2016, 11:29 AM | #21 | |
FASTER!
Drives: Challenger Hellcat, 2SS Camaro Join Date: Apr 2008
I do have a kit I'm about to install on my supercharged 4Runner, but that supercharger from TRD doesn't have an intercooler AT ALL or a heat exchanger, so it will help A LOT. Having said that, I have run the blower on the truck for almost 10 years as is. |
08-17-2016, 12:02 PM | #22 | |
Drives: '98 Pontiac Trans Am Join Date: May 2016
I haven't heard of any negatives besides the extreme scenario where a car is tuned to have it there and then it either runs out of liquid or some failure on the meth system causes a loss of the liquid injection resulting in all sorts of bad possibilities.
2017 1LE Camaro Hopeful
1998 Trans Am M6, Bolt Ons (Daily Driver) 2005 Eddie Bauer Expedition (Family Vehicle) 2007 Z51 Corvette M6 (Salvage Project Car) 1987 Trans Am 350tpi A4 RIP |
08-17-2016, 12:20 PM | #23 | |
Drives: 2001 Audi TT, 2016 Camaro Join Date: May 2016
The long term failure trend was picked up by the Audi world and the general consensus was for a daily driver, the risk wasn't worth it. Once you dial in the advantages of injection into your tune, you can quickly get into trouble if the pump fails or you run out of fluid. For a dedicated weekend warrior, sure, a great investment. Not so much for a DD in my opinion. I would suggest get your fueling on the money first for the power you seek. Then add in water/meth if you want to fiddle with it. |
08-17-2016, 01:29 PM | #24 | ||
FASTER!
I went with the Coolingmist setup for the 4Runner. They had a pretty good rep on the 4Runner forum and without a heat exchanger or intercooler, they make a significant difference on that vehicle's supercharged setup. It basically becomes a chemical intercooler with the octane benefit to prevent detonation. The Camaro kits all have intercoolers and heat exchangers, so not needed IMO. On the 4Runner tune, you can't directly control the timing. The computer still has final control. I simply removed timing from a few places to avoid detonation, but the timing advance is still all OEM. The cooler the charge, and the less the cats heat up, the more timing the computer will automatically feed the engine, thus the meth is a great benefit. On the Camaro, the timing is controlled in the tune and you get what's commanded, so again no benefit there. When I was considering meth injection for the Challenger, the shop I talked to said to just go to N20 and skip meth. It is a WELL respected shop on this forum. You get cooling as well as extra power and the kits were described as much more robust and reliable. Not something you'd want in a DD, obviously, but that's the direction I'll go in the Challenger if I want more. |
08-17-2016, 03:23 PM | #25 |
A few of the Audi folks left their injection systems in place went to just water only injection for hot days, manual toggle. Of course they had to greatly reduce flow since there isn't any fuel value without the meth. The need for meth tuning went away. I didn't think it was worth it myself.
And FYI Speedy, I went from a Snow pump, to a coolingmist pump, and back to a Snow pump. Even ran direct to the battery with a relay. Finally gave up. |
08-17-2016, 03:53 PM | #26 | |
FASTER!
This is the pump that came with mine. Was this what you had? I know at one time the pumps weren't compatible with the meth and it would eat seals in them over time. Not sure if these are newer models that correct that or not, but they claim they are. http://www.coolingmist.com/pagedispl...er_Pumps,parts |
08-17-2016, 05:38 PM | #27 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
The tvs supercharger rotor coating does not really like methanol. It will eventually erode the coating. If you are overdriving the supercharger and getting it really hot then the methanol seems to eat the coating faster. This is from first hand experience on my ZL1.
Everyone I know that advocates the use of Methanol says tune the car to run on the gas in the tank and then spray the Meth on top of it for cooling and a buffer against knock and the negative effects of knock. Since this LT1 motor came out in the C7 and the aftermarket is trying to build powerful motors a lot of tuners are going down the methanol path to get horsepower you just cannot make when you have 11.5 to 1 compression ratio and boost. I'm just going to throw this out there but I don't think anyone can possibly make 750 or more whp on just pump gasoline on a stock LT1 motor. To run this kind of compression and boost you only have a few options. High octane race gas, alcohol fuel (E85) or spray a bunch of methanol and tune the car to use methanol as a fuel to compensate for the octane deficiency. I'm seeing more and more of this kind of methanol use and it was a big temptation on my turbo car to spray a load of meth so I could run more boost. To be honest I'm considering buying a LT4 crate motor from Jegs mainly for the lower compression 10 to 1 pistons. The plus is then I have all of the mechanical fuel Pump and injector upgrades as part of the package and no engine disassembly at all. Anyone interested in buying a slightly used LT1 with only 6000 miles on it and a never been used LT4 supercharger?
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
08-17-2016, 06:28 PM | #28 |
Speedy, I looked at that pump, but we're talking 5-6 years ago when I fooled around with it. Hopefully they have improved over time.
