Vararam
Old 12-30-2020, 03:33 AM   #1
Alfdawg
Drives: 2014 camaro ss
CHARGING TWO BATTERIES DURING WINTER STORAGE HELP
I have a duralast platinum agm battery for my primary battery and a xs power xp3000 for my secondary battery for my car audio system. The batteries are wired in parallel. Negative to negative and positive to positive. My question is can I charge both batteries at the same time with a single battery charger? And also since they are two different brands of batteries but both are agm if I charge them together will it harm either battery?
Alfdawg is offline   Reply With Quote
Old 12-30-2020, 05:11 AM   #2
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
Yes. I've done this for the past 1+ year on two high end Odyssey batteries. I'd only run the charger about once per month (90 minute cycle).
Jack Bilger
granatl is offline   Reply With Quote
Old 12-30-2020, 05:56 AM   #3
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2012 SIM 2SS/RS & z71
Overcharging will harm any battery as in shortened longevity at best, fire or explosion at worst.
Generally batteries truly in parallel need to be the same type and age. Are yours designed to the same specs? If not, one will overcharge while the other charges.
If that is the case then they should be isolated when charging
Sure, you can charge them as they sit. In fact you charge them together now whenever then car is running.
Another important consideration is what type battery charger you plan to use and how long will they sit on them charger? Battery tender or charger? There are ton of info on the internet about which to use in your situation.
Southern Comfort is offline   Reply With Quote
Old 12-30-2020, 07:52 AM   #4
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
It is ok to charge them at the same time. My diesel has dual batteries that are parallel for charging, running, etc.. all the time. As mentioned above I do replace both when I replace one just to keep them the same age.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 12-30-2020, 08:12 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I've been running dual batteries on my 02 Silverado for about 12 years just cabled in parallel. I've replaced the primary once and the secondary twice. It's possible for one battery to go bad and take out the other over time, but I wasn't going to try to find a Duramax dual battery rig with the factory relay setup from a junk yard. I was only able to fit a battery that is about 100 CCA less than the factory one, but it helps with the electric winch and off-road lights.
I don't use a battery tender on it, but I do charge it with a charger from time to time if I'm not driving it much. I'm sure it shortens the life of the smaller battery, but not by enough to make me do it the way the factory does.
I also have a DMax and I did change both batteries together on that because it's the DD and I want it to be 100% dependable. I did not change both batteries when one went dead on a Cummings I used to have, but the batteries were easier to change on it so I was less concerned about having to do it on the road.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 12-30-2020, 10:42 AM   #6
Alfdawg
I was told by a Xs power rep to get at a 15 amp battery charger to charge both batteries and remove the charger once the batteries are charged. And to charge them at once a month.
Old 12-30-2020, 10:43 AM   #7
Alfdawg
And I brought both batteries at the same time. So does that mean they are the same age?
Old 12-30-2020, 10:51 AM   #8
Alfdawg
My primary battery is 80 amp hours and 140 reserve mins and my secondary battery is 120 amp hours and 240 reserve mins. So do you think I can charge them together safely?
Old 12-30-2020, 01:40 PM   #9
Southern Comfort
Personally, I would not design anything to run or charge unmatched batteries in parallel.
Given no other choice, then I’d charge them slowly using a battery tender or low amp AGM charger and remove charger when fully charged.
Old 12-30-2020, 03:39 PM   #10
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
You could always get a dual battery tender. You can remove one of the battery ground cable clamps and charge both batteries at their needed rate. I think I got the one for my boat at Harbor Freight for about $50.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 12-30-2020, 06:29 PM   #11
Camaro2ss2010
There should be dated stickers/codes on the batteries.
