Vararam
Old 10-02-2020, 12:02 AM   #1
L6611983
Drives: 2010 Camaro 2SS
engine rev
I wanted to know if somehow i can wire up this remote to the electronic gas pedal and rev the engine by remote?
L6611983 is offline   Reply With Quote
Old 10-02-2020, 07:06 AM   #2
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
Sometimes I should know better but I can't help it.
WHY?
ADVMax is offline   Reply With Quote
Old 10-02-2020, 07:17 AM   #3
MrChrisLS3
Drives: 2018 1SS M6
WHY?
I don't know the OP's reason, but it would be nice to be able to listen to the engine at varying RPM without having to get someone to operate the throttle.
MrChrisLS3 is offline   Reply With Quote
Old 10-02-2020, 08:18 AM   #4
byrds8
byrds8's Avatar
Drives: 2013 Camaro 2SS, L99
This is true. Not like the old days when you can just throttle it from the side of the carb. Ahhh the good old days...
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
byrds8 is offline   Reply With Quote
Old 10-02-2020, 10:34 AM   #5
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
You can sorta kinda do that with any decent diagnostic hardware/software (Autel, Snap On, Tech2, etc). I have GM GDS2* software with an MDI clone and can activate any module on the car remotely, via wifi/bluetooth/USB, with my laptop. This also allows me to hold the throttle at any rpm. I can check to see if it allows revving, or sweeping through a specific range of rpm, but I don't believe so. The software would need an input for the ramp rate (how quickly you rev it over X time), which I don't know if can enter manually. For example, I can instruct the ECM to hold a steady 2600 rpm while also monitoring O2 sensors, temps, injector pulse, timing, etc...but it only holds that rpm until I press 'Stop'.
*(GM GDS2 + MDI is what GM uses for diagnostics on our car in place of the Tech2, which is used for older GM vehicles.)
So as for revving the engine remotely? I don't know, but I personally wouldn't attempt to tap into the throttle pedal module with a device like this - although I am nearly 100% certain it could be done, just not sure how safely for the throttle pedal module, throttle body, or ECM. My guess is any device like this is at risk of generating a Reduced Power Mode condition or other throttle related CELs. You could probably make an adapter that would allow you to tee into the harness/connector with a much longer cable for use outside the car. What you would have would essentially be a gas pedal for your hand.
L6611983, what's the purpose of this? Is it for diagnostic purposes, making videos, car shows, pure entertainment, etc...? I am just curious what you would use it for as that may impact our answers. What you show would scare me because it looks like it's intended to stay physically connected at all times. Being that it is wireless opens up all sorts of possible issues.
InFiD3ViL is offline   Reply With Quote
Old 10-02-2020, 01:39 PM   #6
mikeman
Drives: 2015 Camaro
I'm thinking he wants to remote start it in a busy parking lot somewhere and then rev it up to surprise/scare people.
mikeman is offline   Reply With Quote
Old 10-02-2020, 02:47 PM   #7
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
I'm thinking the OP wants to rev the engine remotely while trouble shooting under the hood. (chasing mystery noises etc.) While pretty old school I purchased this throttle tool from Lisle a while back. Part # 48700. I think it was under $40. While you can't blip the throttle like a 750 cfm 4-barrel you can bring up and hold RPMs without an assistant. I always use some stout wheel chocks and set the E-brake. Don't want to play neighborhood pinball with the vehicle should something "weird" happen.
ariZona28 is offline   Reply With Quote
Old 10-02-2020, 07:56 PM   #8
L6611983
For diagnostics
