dave@hennessey
Old 06-11-2020, 08:19 PM   #1
Alfdawg
Drives: 2014 camaro ss
Ceramic coat headers
I'm purchasing kooks headers with high flow cats. What I would like to know is should I get the high flow cats ceramic coated too? And also does anyone know if JET HOT coating is good? OR should I get them coated elsewhere?
Alfdawg is offline   Reply With Quote
Old 06-11-2020, 08:34 PM   #2
xc_SS/RS
Drives: 2010 Camaro SS/RS
JetHot is a good company and I’d get the cats coated too. Ask them about doing the inside of the headers. The good thing about going with JetHot is you keep the warranty
I had mine cerakoted and it’s alright stuff. Has held up pretty well, but the coating at the collectors is starting to show some age. If I was to do it again I’d send them to Swaintech
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 06-11-2020, 09:41 PM   #3
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Jet Hot is the best. I do not have my cats coated, but my headers are.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 06-12-2020, 11:49 AM   #4
GodWentPunk
GodWentPunk's Avatar
Drives: 2015 2SS White Convertible CE/INDY
I went with Jet Hot as well. After about 1500 miles, they still look as they came, nice shinny chrome.
joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
GodWentPunk is offline   Reply With Quote
Old 06-12-2020, 12:03 PM   #5
SL33P3R
SL33P3R's Avatar
Drives: 2013 Camaro SS Vert
Depending where you are buying your headers it is usually much cheaper to get them coated by the speed shop. I got my headers coated by CSP for $225 when I bought them. I called Jet-Hot direct about getting them coated and they wanted 3 times as much.
SL33P3R is offline   Reply With Quote
Old 06-12-2020, 05:03 PM   #6
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Jet hot is a rip off and i've heard the coating doesn't even last. Had Jannetty send mine to their guy. $300 coated inside and out. They wanted over $1k to do mine because i'm supercharged. I promptly hung up.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 06-12-2020, 08:01 PM   #7
2011SSCT
2011SSCT's Avatar
Drives: 2011 Camaro 2SS/RS
Same here, had mine done through Jannetty's guy. I think it was around 300 bucks, took them 2 days and they coated them inside and out.
L99 to LS3, Whipple 2.9 Blower with 3.750 pulley, ID1050x injectors, JRE Rough Idle Blower Cam, BTR Bronze Bushing Trunnion Kit , JRE/BTR .660 Springs, BTR Pushrods, Melling High Volume Oil Pump, ZL1 Fuel Pump, JRE FPCM, JMS BAP, JRE 90MM Ported Throttle Body Circle D 3200 Stall Converter, Ceramic Coated Kooks Long Tubes, Kooks Full Exhaust with Hi Flow Cats, Cold Air Inductions Intake With JRE Scoop, JRE Built Rear Differential with Billet Caps, 3:91 Gears and Eaton TrueTrac Posi, JRE Dyno Tune, Moroso Wires, Moroso Catch Can, Factory Reproductions Gloss Black ZL1 Wheels. 659WHP/566TQ
2011SSCT is offline   Reply With Quote
Old 06-12-2020, 08:14 PM   #8
Quicksilver-SS
Quicksilver-SS's Avatar
Drives: 2014 1SS / RS M6
I ordered my Kooks from Jet Hot and they coated the cats too. Only been on 6 months but look as good as the day I put them on.
Quicksilver-SS is offline   Reply With Quote
Old 06-12-2020, 08:52 PM   #9
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
WTF does that matter?! Because of the exhaust heat increase when supercharged? If so, what do they do, spray on a thicker coat...mixed with 24k gold flake?
$1,000 for a coating my ass!
InFiD3ViL is offline   Reply With Quote
Old 06-13-2020, 10:16 PM   #10
Greenhornet2
Dunno, she tried to tell me i needed the higher heat coating. My headers now look brand new at a fraction of the price and through jannettys experience will stay that way for decades.
Old 06-14-2020, 01:27 PM   #11
pyroguy
pyroguy's Avatar
Drives: ABM #831
Not sure why they wanted $1,000 for a supercharged coating for you. I know there is a different coating that goes up to a higher temperature for forced induction applications as the heat does go up. Still $1,000 is more than I've seen quoted for the higher temp coating historically.
