Old 10-25-2019, 10:46 PM   #1
Wattacar
Wattacar
Drives: 2016 Camaro 2SS, 1969 Camaro Z28
Irregular ride height.
I have a new-to-me 2016 2SS WITH MCR and front right(passenger)ride height is a good 1/“2 lower then the left(drivers side). Car seems to driver nice and straight. Only has 10,000miles.
Parked it a couple times and places and nothing helps.. looking for some guidance.. maybe just an alignment/camber check?
Wattacar is offline   Reply With Quote
Old 10-29-2019, 06:07 PM   #2
zirad54
zirad54's Avatar
Drives: 2017 Camaro 2SS, MRC, NPP,
what are the actual measurements for all 4 corners? and are all 4 tires inflated to the same pressure? Are the tires the same size, side to side (don't assume they are the same, dealerships do some shady az stuff).
zirad54 is offline   Reply With Quote
Old 10-29-2019, 08:12 PM   #3
Move_Over
Drives: ISO ss 1le
Make sure to measure from hub to fender not ground to fender. Also camber can play with height as well so good idea to get the alignment checked
Move_Over is offline   Reply With Quote
