Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
JUICEDMOTORSPORTS
Old 08-15-2019, 08:54 AM   #1
Ittookalongtime
Ittookalongtime's Avatar
Drives: 2018 1SS 1LE Summit White
SS 1LE dif oil
Probably redundant, but I did a change (had done) and sure enough there was a lot of gunk and shavings. Car has 2500 I bought it at 2000. It also still had the shipping blocks on it (I found them earlier). First owner not too concerned.
Gary
Austin Texas
Ittookalongtime is offline   Reply With Quote
Old 08-15-2019, 10:08 AM   #2
VinnAY
Drives: 18 1SS/1LE
Thanks for the update.
Old 09-10-2019, 01:50 PM   #3
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Mine was clean as new oil at 1500 like I thought it would be.
ssmofo is offline   Reply With Quote
Old 09-10-2019, 11:29 PM   #4
MR.1LE
MR.1LE's Avatar
Drives: 2019 1LE
Do I really need to change it at 1500? I just hit that mark..
MR.1LE is offline   Reply With Quote
Old 09-12-2019, 06:56 AM   #5
19SW1LE
Drives: 2019 SS 1LE
If you're going to track the car, yes according to the manual supplement.
19SW1LE is offline   Reply With Quote
Old 09-24-2019, 05:13 PM   #6
FH212
FH212's Avatar
Drives: 2021 Camaro SS 1LE
What about if its never tracked?
2021 Camaro 1SS 1LE - Red Hot - A10 (Yes, Automatic)
2017 Camaro SS 1LE- Red hot - SOLD
2001 Mecham Trans Am #3 - 7.0L LS1
2015 Lexus GS350 F Sport - Nebula Grey
FH212 is offline   Reply With Quote
Old 09-25-2019, 04:01 PM   #7
funked1
funked1's Avatar
Drives: 2019 1SS 1LE
I am looking at the 2019 manual and supplement right now and there is nothing about a change at 1500.
Originally Posted by Page 172
Rear Axle Fluid
Axles must have 2 400 km
(1,500 mi) before being used in
track driving.
The rear axle fluid temperatures
may be higher than when driving in
severe conditions. Drain and refill
with new fluid after the first racing or
competitive driving event, and then
after every 24 hours of racing or
competitive driving. See
Recommended Fluids and
Lubricants 0 328.
Edit:
I found this on page 188:
Originally Posted by Page 188
. Should the vehicle be used
for racing or competitive
driving (after break-in), the
rear axle lubricant must be
replaced beforehand.
I like how they place conflicting information across three different manuals...
funked1 is offline   Reply With Quote
Old 09-25-2019, 04:06 PM   #8
funked1
funked1's Avatar
Every 45k miles.
Old 09-25-2019, 10:53 PM   #9
Daily1LE
Drives: 2018 Camaro 1SS 1LE
I just did the rear diff fluid on my car at 8k miles. I never raced the car and the fluid was rather dark. I attached the pics of the drain plugs too which were nasty.
Daily1LE is offline   Reply With Quote
Old 09-26-2019, 10:48 AM   #10
ssmofo
ssmofo's Avatar
Thats normal.
Old 09-26-2019, 01:10 PM   #11
Hailwood
Drives: 2019 SS 1LE
I did a couple autocrosses before I changed mine (@1500 mi) and it was dark and sparkly (similar to Daily1LE). Glad I changed it before the time trial this weekend.
Hailwood is offline   Reply With Quote
Old 09-26-2019, 03:14 PM   #12
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Correct me if I am wrong, but my understanding is that a mechanical limited slip diff has clutches. I believe those clutches will wear through normal use, and shed material in the process. Is my understanding correct?
Emoto is offline   Reply With Quote
Old 11-20-2019, 08:58 AM   #13
s346k
s346k's Avatar
Drives: 18 1SS 1LE
the car doesn’t care where it is driven hard. if you flog it, change the oils regularly.
performance car stuff 101
Old 11-20-2019, 03:38 PM   #14
oOKhanhOo
Drives: 2018 SS 1LE
I changed mine around 3000 mileage. It was gunk on the drain bolt and dark fluid. I don’t plan on tracking mine. Maybe one or autocross event next year. I don’t think it hurts to just drain and clean the gunk off. I believe it’s worth spending $40 for 2qts and do it yourself.
oOKhanhOo is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
