04-08-2021, 02:32 PM | #1 |
Drives: 2014 camaro ss 1LE Join Date: Apr 2020
lets talk mufflers and drone
I currently have kooks long tubes with a hallowed out cat setup with kooks mufflers. its 3 inch all the way back.
I need to stick with 3 inch but it drones like a MFER is there a muffler out there everyone likes that wont drone so damn bad?
2014 SS 1LE summit white
RWHP 1032 Modifications are as follows: Engine, forged and stroked 416 CI, Procharger F1A-94 with upgraded race intercooler and big red blow off valve, HP Tuner, AEM Wideband with Gauge, TSP Supercharger Camshaft 224/240 .615/.615 112 +3, Brian Tooley Dual Valve Springs, Brian Tooley Chromoly Pushrods and ported heads. Fore innovations twin 450 pumps on E-85 Brian Tooley Titanium Retainers, GM 3 Bolt Conversion, New GM Oil Pump, Injector Dynamics ID 1700 Injectors, Kooks 1 7/8" Long Tube Headers , |
04-08-2021, 03:32 PM | #2 |
Instagram: Sangstah
Try a resonated x pipe, should help with drone.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
04-08-2021, 03:52 PM | #3 |
Started#gottalovethatblue
Corsa has a 3” system and they’re said to be drone free. Also, you might look into Solo’s J pipes. They cancel out resonate frequency so that the car won’t drone.
04-08-2021, 03:54 PM | #4 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Replace cats...or...resonated x pipe....and/or...I have Borla Touring mufflers. Granted the touring mufflers are quieter, but have a nice deep mellow sound..and no drone.
Good luck.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-08-2021, 04:37 PM | #5 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Get Corsa axle back. Zero drone. Life is good.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
04-08-2021, 04:38 PM | #6 |
Drives: 2012 Camaro SS Join Date: Dec 2019
No x pipe? It will sound and perform so much better and reduce drone
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-08-2021, 07:12 PM | #7 |
^^^ this for sure!!
04-08-2021, 09:14 PM | #8 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Axle back? Only cat backs are made for the 2010. Or that’s all I have found.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
04-09-2021, 08:45 AM | #9 |
i pulled the hallowed out cats and had some race bullets installed but did almost nothing reduced it slightly was nasty up until about 85 and now its only nasty up to about 80. she pops alot more for some reason which i like haha.
04-09-2021, 09:52 AM | #10 |
Drives: 2011 Camaro SS Join Date: Jul 2019
You need mufflers that produce a higher tone. Spintech sounds great Corsa or Borla are good as well. But those Spintechs sound nasty. They are loud tho.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
04-09-2021, 10:20 AM | #11 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I have TSP long tubes and there 3" exhaust system with mufflers and have no drone. Before this I had a resonator and muffler delete on the 2.5" factory exhaust and now it's actually quiter on the highway with the TSP exhaust.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
04-09-2021, 11:10 AM | #12 |
Does Corsa even sell an axle back for our cars? I have looked for the Xtreme mufflers in an axleback version but all I ever seem to find is full catback setups.
04-09-2021, 11:11 AM | #13 |
Try their website. I thought I saw them in there last year.
04-09-2021, 11:27 AM | #14 |
Ok, will do. I thought I only saw them for the 6th gen.
