04-08-2021, 01:46 PM | #29 |
Drives: 221SS1LE Join Date: Oct 2008
The car will tell you when to shift grasshopper I grew up driving a manual, and listening to the car and feeling the car are just normal to me, so it's hard to explain how to drive a manual besides the obvious stuff. I'm a truck driver and I float gears which is not using a clutch in most scenarios, hell I even shifted gears on my motorcycle without clutching! So you're just gonna have to listen to your car and get the feel of it and you should be just fine.Good Luck
04-08-2021, 02:36 PM | #30 |
Drives: '21 Wild Cherry 2SS M6 Join Date: Nov 2020
Yeah, on my motorcycles its pretty easy to shift without the clutch.
in the SS its not hard to know When to shift, it is doing it well\smoothly that will take practice.
2021 Wild Cherry 2SS, M6, NPP, MRC
https://natmus.org |
04-08-2021, 03:19 PM | #31 | |
Drives: 2020 2SS 1LE Join Date: Jun 2020
04-08-2021, 05:19 PM | #32 |
I've piddled around with Comp Mode, just to verify that it turned on really. But I'll give that a shot and see how it goes.
04-08-2021, 07:27 PM | #33 |
Drives: 2021 Camaro LT1 Conv Join Date: Oct 2016
04-08-2021, 07:30 PM | #34 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
How to get to Carnegie Hall...
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
04-08-2021, 07:45 PM | #35 |
Drives: 2020 2SS Vert/M6/F250 SD Join Date: Jan 2021
Seethru... is that a Hurst? I dont see their name on the side there. I put Hurst shifters in all my old Vetts. You used to have this T handle to pull up with 2 fingers to get into reverse... Absolute crap.. had to go. The Hurst was a must back then. And I love the white knob....
But.... I read about putting it in and dropped the idea after the process involved having to pull a cross member and jack the tranny some.... Did you do that? And if so how was it to get done?
04-08-2021, 07:55 PM | #36 | |
04-08-2021, 08:01 PM | #37 | ||
You will need these two items. https://bartonshifters.com/shop/ols/...t-knob-bcm-psk https://bartonshifters.com/shop/ols/...t-knob-adapter |
04-08-2021, 08:29 PM | #38 |
OK. Just a knob swap. I liked the idea of a Hurst short throw shifter until I looked at the process. Someone in here said it didnt make all that much difference... I dont know if its worth it. The shifting generally feels pretty good to me and needs a lot of break in before I make any decision.
I do prefer the white knob though. Looks so 60s...
04-09-2021, 11:26 AM | #39 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Truth be told, I got started with double-clutching on downshifts in cars with small-displacement engines that hated to be 'lugged', and it just made sense there. Think sports cars and subcompact sedans here. It was some years later that I figured out that the input side of the transmission could slow down too far too fast in the cold and that it might make sense to give everything ahead of the synchros a rev kick to make their job somewhat easier.
I hear you on skip-shift. Would definitely piss me off to have to drive differently than I otherwise would just to avoid it. And I'd be likely to encounter it between my house and the main roads. Norm
'19 WRX 6M (the family sedan . . . seriously) |
04-09-2021, 10:48 PM | #40 |
I had a 1958 Dodge Power Wagon Panel truck. All original driveline with flathead 6 and a granny low 4 speed. 2 speed transfer case that would go about 2 MPH in first low range foot to the floor. Then the clutch fork broke in the trans. I drove with no working clutch for a month. I would start it up and warm up the engine. Then shut it down and slip it into first or reverse and start it up in gear and leave. To stop I slow down and then shut it down in first. The crank it up and go. Its easy if you have low enough gears. Ive had to do similar things with a tractor trailer too because of clutch cable failure in a cabover.
04-10-2021, 07:28 AM | #41 |
Drives: 21' LTI, '18 Traverse, '15 Mazda 6 Join Date: Oct 2020
I wouldn't feel too bad, I've had hundreds of thousands of miles in 4 manuals before my LT1 and it is by far the hardest to drive smoothly. Not really sure why but possibly the throttle mapping. I've definitely noticed times where if hit the gas a certain way it "falls on its face" before going. It drives really good aggressively but definitely does some weird stuff sometimes when trying to drive normal.
04-10-2021, 09:30 AM | #42 |
Drives: 2021 2SS 1LE Join Date: Aug 2020
To the OP, there are a few simple things I'd suggest to make your learning easier.
1) Warm up the trans. The trans won't shift smoothly when you first start driving and the OEM fluid is cold. Drive for like a half mile or so in 2nd or 3rd gear at 1500 to 2500 RPM. Once warm, the shifts get much smoother 2) When starting from 0 mph, shift from 1st to 3rd. The 1st to 2nd is often notchy. Add in the the stupid OEM skip-shift function that blocks you from shifting from 1st to 2nd (to save gas) under certain situations, and odds are you aren't going to be able to smoothly shift from 1st to 2nd. I've been doing the 1-3 shift since I got the car 6 months ago and it works well every time. 3) Always set the auto rev match to "on," each time you start the car (the default on start up is "off"). It definitely helps smooth out the driveline engagement when you let the clutch out. |
