03-16-2021, 10:05 PM | #1 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Wire coming from battery?
Probably a really easy question to answer for you guys on the forums but I believe my ZL1 came with a battery tender of some sort from GM. But what does it plug into and or what will i need to buy to make it work?
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
03-16-2021, 10:36 PM | #2 |
This connector looks remarkably similar to the one on my (very high quality, strongly recommended) TecMATE OptiMate trickle charger/battery tender: https://www.amazon.com/gp/product/B003UANXCE
The "standard" GM battery tender with part number 84020223—that is actually a CTEK unit—has a different hookup, so I don't think that would have been it.
03-17-2021, 12:44 AM | #3 |
Drives: 2017 ZL1 Join Date: Aug 2020
Looks a lot like the end of my battery tender
03-17-2021, 06:33 AM | #4 |
Drives: Buick Grand National, BMW M5 Join Date: Nov 2019
Definitely looks like a connector to a Battery Tender/Trickle Charger. I would follow the wire to make sure it’s hooked up correctly to the positive and negative terminals of the battery before use.
03-17-2021, 07:32 AM | #5 |
Remove the battery cover and see whats in there... looks like a charger cable. Was this car new??
2018 ZL1-NFG-A10
New Iron L8T 9.32 147MPH |
03-17-2021, 07:56 AM | #6 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Definitely a battery tender quick connection. They are almost all pretty standard and will fit most of the battery tenders with a quick connect on the market. Would have not been installed from the factory so make sure its connected to the terminals correctly before you plug anything in to it (even though most tenders will not charge in reverse polarity).
03-17-2021, 08:06 AM | #7 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
Definitely a tender plug, just likely not the OEM one
The CTEK plug will look like the first one I have shown below while yours looks like the 2nd pic which is a Sears Diehard brand that I have on my wife's SUV
03-17-2021, 08:42 AM | #8 |
Had to add this also, without the other charger end you just have the wiring hookup and will still have to buy a trickle charger anyway, best off to buy one you like and replace that wiring with the one that comes with the new one
03-17-2021, 11:13 AM | #9 |
Thanks for the response everyone, it came with a car cover so maybe the previous owner stuck it in there because i can't find it anywhere else in the car. I am almost positive it mentioned something about a charger for the battery on the window sticker.
