11-25-2020, 10:51 AM | #1 |
Drives: 2010 Camaro SS, 2013 Cadillac CTS V Join Date: May 2020
LSA Swap on Dyno
Its been a process to this point, but FINALLY first start up and I am STOKED how well it went. Literally what you see in this video is the actual first start up. I am shocked how quickly and almost effortlessly it started. Few minor trips to Advance for extra hoses because we wanted to route the pump slightly different than the instructions recommended, its such a TIGHT fit in that bay. I am lucky to know and get the pleasure of hanging out with Prbeauty as well. I am not a huge fan of how I routed the hose from the heat exchanger back into the bottom entry port of the blower...it just looks like a BIG a** hose sitting there. Suggestions? Tia.
https://youtu.be/gwoYLn3Aysg Last edited by AmandaRaeJean; 12-16-2020 at 09:18 PM. Reason: Update Thread |
11-25-2020, 12:53 PM | #2 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Did you use the ADM instructions?
A lot of how it’s routed is detailed there. I’m now running 3 heat exchangers, dual varimax pumps since I wrote the guide. Lots of info in my build... The guide is in my first post: https://www.camaro5.com/forums/showthread.php?t=385577 Congrats! -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
11-25-2020, 03:27 PM | #3 |
That's so Awesome. I want to do this conversion, but it's going to be a bit down the line. I have so many things I want/need to do to my car still...like the rest of us.
I subscribed to your YT channel. I thought I did it a couple months ago, but guess I hadn't. Gotta support that Camaro content!
11-25-2020, 05:09 PM | #4 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Awesome conversion! Well done.
I did mine this past spring, I’m also not a fan of how congested the bay is. I’m thinking of moving the coils from the valve covers to free up space. After that there may some ideas that pop up once there is more room.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
11-25-2020, 05:24 PM | #5 |
Drives: 2010 1SS Join Date: Aug 2015
Awesome.. keep us posted!!
Might be ok or just the view but that clamp back by the intercooler reservoir looks like it is not tightened? Good luck with the tune!
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
11-25-2020, 08:50 PM | #6 |
If you don't mind me asking, what did it cost you total (not including tuning) for the conversion?
11-26-2020, 07:26 AM | #7 | |
We did use the instructions that came with the kit, very detailed. We followed them step by step. I don't recall it exactly stating which way to route the hose, and to be quite honest I remember the picture being the only way it shows the "hoses are to be routed". I could be wrong. Or maybe I over looked it. I will check out guide in your thread and compare it. There is SO MUCH ROOM in front of the heat exchanger. I am amped by that space. |
11-26-2020, 07:27 AM | #8 | |
Awesome! Thank you. I appreciate the support. Slowly but surely buy parts. Thats what I did. def didn't just BAM bought it all. So dumb pricey lol |
11-26-2020, 07:28 AM | #9 |
11-26-2020, 07:34 AM | #10 | |
-_- So add that in... and watch the tears roll. |
11-26-2020, 08:13 AM | #11 |
USA-1
Need a review Amanda! Go drive it!!!
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
11-26-2020, 08:19 AM | #12 |
12-07-2020, 06:51 AM | #13 |
Small update! Tune is scheduled! I have a few codes I saw while waiting for tune that I ran with my scanner. P07E8 I can't seem to find anything on. Anyone have anything on this? The only other code that matters is P0A4A. The other codes are items we deleted that just need to be deleted in tune. TIA
12-07-2020, 12:24 PM | #14 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
I would love to do this on my Sedan. When I go from the ZL1 to the Sedan there is such a big difference. The Sedan is only 390rwhp and the ZL1 is 523rwhp. I like driving the Sedan more because it has a lighter feel to it.
