Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - New England > Local Marketplace
Old 07-02-2019, 09:22 AM   #1
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
2004 GTO M6 with fresh motor
Up for Sale is my 2004 GTO Quicksilver M6 with red interior. Engine recently rebuilt due to a rod bearing issue. Replaced crankshaft and rod due to the damage, along with alot of other stuff! Runs great. 13k OBO... open to trades... GM vehicles only, preferably LS vehicles (CTS V, fbody, corvette).
Body Miles: ~101k
Engine rebuilt (100 miles ago):
Stock bored retained - Cylinders re-hatched with flex hone
New piston rings – stock gaps
New main and rod bearings
New GM stock crankshaft
Stock rods (1 new rod)
Stock pistons
New BTR stage 2 cam
New BTR .660” Dual Spring kit on stock milled heads
ARP head studs
Double roller timing chain set/ w/spacers
LS2 timing chain damper
LS3 Lifters
New Comp Cam 7.4” pushrods
Ls1 rockers with trunnion upgrade
New Melling high pressure oil pump
New oil diverter
New oil pickup
New flexible dipstick tube
Exhaust
Kooks Long tube headers
Hollowed out cats (codes tuned out)
flowmaster catback
Intake
LS6 Intake
FAST 78mm TB
K&N Cold Air Kit with over sized filter
Fuel
LS6 fuel rail and injectors, rail mount fuel pressure gauge
Drivetrain
LS7 clutch
Tick Speed bleeder
Short throw shifter
new tranny and rearend fluid
Electrical
New plugs/wires
AEM Tru Boost (in preparation for boost...)
AEM Wideband
Custom color matched Oil Pressure gauge
dual gauge pod
raptor shiftlight
HPTuners tuned
Trunk mounted battery
Suspension
1” lowering kit
TSW 17” wheels
relatively new tires
The Good:
Mechanically the car is great. Probably 100 miles on the motor setup and it runs strong (~400rwhp or 450-475hp @flywheel).
Fun, loud and fast
The Bad:
The exterior is fair. No rust/body rot. But there are a ton of chips, side view has been scraped against in parking lot, drivers rocker panel has a chunk that was ground off, trunk lid had some scratches on it. Overall I'd rate the exterior a 6 out of 10. It looks good from 10-15ft away.
A/C could use a charge
Interior has some trim pieces that are damaged
Buy as is, no warranty implied.
Do not contact me about helping to sell this. I will ignore lowball offers. If you want to pay $8k, look elsewhere.
Come see the car in person, no test drives without cash in hand.
PM me your phone number and I can text pics.
Some pics can be seen here: https://boston.craigslist.org/sob/ct...924554262.html
***Additionally*** - I do have some addition items I could work into a deal:
Fresh 550hp LS3 (new)
Partial APS Extreme TT GTO kit (new)
AEM Methanol Inj kit (new)
RealQuick is offline   Reply With Quote
Old 07-27-2019, 11:27 PM   #2
RealQuick
Sold
