Old 08-08-2020, 02:44 PM   #1
keystonemedical
keystonemedical's Avatar
Drives: 2019 ZL1 / LE , 2014 CTS V
AWE LinkPipes
I have a set of AWE LinkPipes. I purchased these for my 2019 ZL1 / 1LE and never installed them. 245.00 shipped to the lower 48 states only.
keystonemedical is offline   Reply With Quote
Old 08-13-2020, 05:44 AM   #2
keystonemedical
still available...
Old 08-24-2020, 03:19 PM   #3
appleman22
Drives: 2017 1ss 1le
do you know if these mate up to the factory exhaust setup? I keep finding conflicting information
appleman22 is offline   Reply With Quote
Old 08-24-2020, 03:55 PM   #4
PROMETHEUS
PROMETHEUS's Avatar
No they don't! They are made to eliminate the secondary cats. So if you use them on the OEM exhaust, you will have to cut out a section of your exhaust, where the secondary cats are.
The biggest advantage is if you go with an AWE catback exhaust, all you have to do is remove the entire OEM exhaust, just in front of the secondary cats and then bolt up these along with the AWE catback. No cutting required on either the AWE or the OEM. I have the AWE track edition catback with these links pipes. It took about two hours to remove the OEM and bolt up the AWE.
Old 08-24-2020, 04:17 PM   #5
appleman22
I know that they are meant to eliminate the secondary cats what I mean is once I cut my secondary cats out will The awe link pipes bolt and clamp into my factory system no problem
Old 09-04-2020, 01:06 PM   #6
sspddmn
sspddmn's Avatar
Drives: 2018 ZL1 1LE and 1991 Z28
If you still have them ill take them. PM sent.
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2016 Audi A6 Prestige Supercharged 3.0 V6 // 2002 Camaro SS (sold)
sspddmn is offline   Reply With Quote
