07-29-2023, 08:08 PM | #15 |
Mechanically they are different, but they perform the same function, and the same principles apply.
'20 ZL1 1LE A10,
07-30-2023, 10:34 AM | #16 | |
I do agree with the aggressive gearing from the A10, even a NA car can face a lot of traction issues. So a larger stall would probably only be utilized at a well prepped track. Another function for higher stall converters is too "soak" up the cam. Big cams need to idle higher and that can cause issues with a tight stall because the engine will want to pull through the brakes if the converter isn't loose enough.
2016 NFG 1SS A8
07-30-2023, 12:15 PM | #17 | |
I sent my 2001 SS LS1 to lingenfelter 20 years ago and one of the mods they made was a looser converter and I think they put a cam in it too.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 07-30-2023 at 03:19 PM. |
