03-17-2017, 11:47 AM | #1 |
Drives: 2016 1SS (12/10/2016) Join Date: Jul 2015
Track Prep - Brake Fluid Amount
Last year I had my 1SS in for some recall work, and while it was there I had them change my brake fluid. I handed them 3 bottles of Motul 600. I was thinking 2 would be enough, but wanted an extra just in case it was needed. They of course flushed all three bottles through. (Which was fine with me).
Ok, one year later, time to change the fluid with fresh Motul 600. At almost $20 a bottle, I’d rather not waste it, but this is the brakes we're talking about, so this is not the place to cheap out. How much fluid is actually needed to do a “full” system flush, and know it's all good? |
03-17-2017, 11:56 AM | #2 |
Drives: 17 white 1LE Join Date: Feb 2017
I had this question too.
Thanks for asking it |
03-17-2017, 11:58 AM | #3 |
I used to be Dragoneye...
The full system is just under one liter, if I remember right.
A year may be enough time (depending on miles, temp, and conditions) to discolor the fluid enough to tell a difference between the old stuff and the new stuff...and obviously, that is the goal of a thorough bleed. |
03-17-2017, 01:32 PM | #4 |
Drives: Red Hot track candy Join Date: Oct 2009
Guess what guys??? I'm doing this in about 20 minutes. Perhaps I can be convinced to add a teaspoon of super blue to figure out the flush rate??
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
03-17-2017, 02:08 PM | #5 |
haha do it do it!
03-17-2017, 02:20 PM | #6 |
Ewwe.. It's turning GREEN!!
03-18-2017, 07:44 AM | #7 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
03-18-2017, 03:05 PM | #8 |
So, OminouSS: what's the verdict? 2 bottles or 3?
03-18-2017, 06:21 PM | #9 |
Drives: 2016 1SS Join Date: Jan 2016
2 bottles ( or 1 of Castrol SRF)
1SS, Black, Black Wheels, A8, MRC, NPP
03-19-2017, 09:45 PM | #10 |
hahaha. Man I didn't even realize that at the time. My car is celebrating St Pats!!!
03-19-2017, 09:52 PM | #11 |
Ok...so, it was right about 1200 ml of Motul. I probably could have done it with two bottles, but I went super thorough on the right rear. As you know that will take the most fluid and I started there. It took me a side to get the color comparison down. I think it was Joe who said 1 liter? He's about spot on. I plan to run it a hundred miles and draw some fluid to inspect to see if it diluted. I never figured how a gravity flush really cleaned out the whole caliper.
03-20-2017, 03:43 PM | #12 | |
Drives: 2016 1SS Join Date: May 2016
03-20-2017, 08:47 PM | #13 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
As long as you don't break the system open and introduce any air it is pretty easy to bleed the brakes at home using the pump/hold/open method.
I plan on putting some DOT 5.1 in mine here soon as well. |
03-21-2017, 12:07 AM | #14 | |
I have a Joes Tire temp digital guage too that I'll shoot across it next weekend. I just don't know how much I can rely on that given it's aluminum and what I really want to know is the temp of the pad or steel cup. I'm all ears if somebody has a reliable method.
