Old 07-16-2019, 04:36 PM   #1
CodemanZLE
CodemanZLE's Avatar
Drives: 2019 ZL1-1LE
LT4 PIDs for Oil Pressure and Boost?
Hey all,
New to the 6th gen world after trading my 5th gen ZL1 for a ZL1-1LE. I imagine I'm going to eventually go dual Aeroforce, but in the interim, I've been using the Torque Pro app (with GM PIDs enabled).
For the most part it works great, but I'm having trouble with a couple of sensors that previously worked fine on my 5th gen. Any advice would be appreciated:
  • Oil Pressure
    • The default Oil Pressure PID always returns 0.
    • Somewhere else I found mention of PID 22115C, however it seems to read ~5+ PSI high vs the DIC and occasionally spikes very high, so I have my doubts...
  • Boost/Vacuum
    • Vacuum reads fine, but no boost is reported
    • Is there not a dedicated PID for boost on the LT4?
    • Manifold pressure works, but I can't find a way to perform a calculation in Torque with 2 PIDs (IE: MAP - Baro)
Has anyone gotten the above to work properly?
Thanks again. Spent a good amount of time searching on a few different boards but never saw a working fix.
CodemanZLE is offline   Reply With Quote
