05-15-2018, 02:36 PM | #15 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
The HP numbers that are being put out are no longer going to be met with normally aspirated (N/A) engines. So, they have to go with boost. Chevy (and GM) has had great success supercharging their pushrod engines, but supercharging is quite inefficient in terms of fuel efficiency. Turbos do a better job here. So to get the ultra high power numbers (current goals my be north of 800HP at this point), and if you still want to have reasonable MPG's turbos are the way to go. But now, if we are talking about a V-8 engine, you will probably need two turbos and a lot of plumbing, which leaves less room for the engine. So, you have to downsize the engine to fit all this stuff in the engine bay, which means lower displacement. As described above, if you have displacement limitations, RPMs can help (along with more boost in a boosted engine). Now, if you read my long diatribe above, you know that the torque of an N/A engine is determined by displacement. But in a boosted engine, it is determined by both the amount of displacement and the amount of boost. The good thing about turbos is you can tune them to add boost where you want it in the RPM range. So you can make turbos that kick in early to make extra torque down low where it is missing from a DOHC engine, and use waste gates to spill extra boost in the upper RPM range where it would be too much. This (along with many other engineering tricks) helps get remove most of the turbo-lag and non-linearity inherent in a turbo design. The new "hot-V" designs that the Germans have been using has been able to strike a nice balance between getting the good low end grunt we like, and still having HP in the upper RPM range (a lot of the 2.0L turbo 4 bangers run out of steam a bit too early in the RPM range for my taste). The downsides are very high complexity, reliability, price, and heat management. That's why these only come in very high priced cars. But in reality if you want to get 700 or even 800+ HP, an N/A engine would either have to have huge displacement or have to rev to the moon (probably both). So the twin turbo hot-V V-8 is a nice solution. It will be interesting to see what Chevy is up to now that Cadillac has showed it's hand. The Cadillac engines are Cadillac exclusive, so there is room for Chevy to go with a larger displacement, or go with a flat-plane crank like Ferrari and other supercars do. |
05-15-2018, 02:48 PM | #16 |
So, now you may ask, "well, why can't they to a twin-turbo hot-V OHV engine instead of OHC?". The short answer is that the two valve design won't give enough flow though the heads to accommodate a boosted application.
The guys who love the DOHC engines always say that they have better flowing heads because they have four valves instead of two. But that is only true when comparing two engines of SIMILAR DISPLACEMENT. Remember that the advantage of the OHV engine is you can have more displacement. More displacement means bigger cylinders. Bigger cylinders can accommodate bigger valves. So when you go over to DOHC, you not only have to make the valves smaller because there are more of them, you have to make the even smaller still because the cylinders are smaller too. You couldn't physically fit an LT1 intake valve in a Coyote engine, so they HAD to go to four valves or lose flow. But if you compare the cross sectional area of the on LT1 intake valve and compare it to the two Coyote valves, they provide almost the same amount of flow. So, in reality, the Coyote heads don't really have some huge advantage in flow capability compared to the LT1 engine. It would if the LT1 was the same displacement, but it's not. Bigger cylinders accommodate bigger valves. But in this case, they are downsizing displacement AND adding boost (which requires even better flowing heads). Hence, DOHC is the way to go for this application. |
05-15-2018, 02:56 PM | #17 |
Drives: Current Camaro-less Join Date: Jul 2014
FYI...the Corvette getting a mid-engine OHC engine isn't a rumor..the CAD drawings have already leaked.
05-15-2018, 02:58 PM | #18 |
Well namely that the Chevy engine chart leaked a few months ago doesn't list the LT1 past..I think 2022? I forget where that was..might have been down in general discussions. The V8's that are marked for production past 2020/2022 are all of a smaller displacement which would indicate either a DOHC N/A or boosted applications.
05-16-2018, 07:11 AM | #19 | |
Drives: E92 BMW M3 Join Date: Oct 2012
J-Rod Built and Matt@FSP Tuned |
05-16-2018, 01:39 PM | #20 | |
Drives: 21 Bronco Join Date: Jun 2012
Why is every other GM motor an OHC design then? Why does the colorado have an OHC engine? |
05-16-2018, 01:58 PM | #21 | |
Fast forward to today, and the newer technology (especially direct injection and variable valve timing) made the pushrod engine design able to compete in MPG's. But I doubt GM or anyone is going back to OHV engine design. Manufactures are trying to make global cars that can be sold everywhere in the world, and much of the world has a displacement tax. The key advantage of the OHV engine is that it allows for more displacement given the size and weight limitations from the chassis it's going in. GM isn't really selling full size pickups around the world, so OHV is fine for now in that application. But for other vehicles, it is to GM's benefit to reduce displacement for overseas sales. By the way, Chevy does make a 4.3L OHV V6 engine, and puts it in the Silverado (it's an LT1 with two cylinders missing, kind of). What is fun, is that that would make it a 90 degree V6 rather than the usual 60 Degree V6. Which I think sounds much better than the 60 degree V6. |
05-16-2018, 02:17 PM | #22 | |
I am not trying to be argumentative just trying to learn. |
05-16-2018, 02:44 PM | #23 |
Well the OHC motors, from a position of being easier to configure, offer better control over emissions to a degree. Mind you this can be mitigated if GM went to a "cam in cam" design like the Viper had.
05-16-2018, 03:03 PM | #24 | |
05-16-2018, 03:19 PM | #25 |
Ok that makes sense then! Thanks!
05-16-2018, 03:20 PM | #26 | |
05-16-2018, 05:10 PM | #27 | |
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
Unfortunate that GM canned it....saw a lot of fast cars with it...even in FWD setups..
05-16-2018, 06:45 PM | #28 |
I've never seen a real Typhoon (turbo 3800) believe it or not!
