06-12-2019, 09:09 PM | #29 | |
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound) Join Date: Feb 2019
06-12-2019, 09:14 PM | #30 |
Drives: 2017 ZL1 Camaro Join Date: May 2018
OP, have you ran the car in sport or track with all nannies off? (Hold the traction control button on the center console for 7-8 seconds)
Even in sport/ track mode there is still power being pulled unless you do the button hold. We get 100 degree humid heat in the midwest and can feel the reduced power but the car still feels quick. Typically I'm down 2-4 MPH in the 1/8th mile from summer heat compared to cool fall air.
2017 Garnet Red ZL1 A10
Other Rides, 97 Trans Am, 72 Chevelle |
06-12-2019, 09:22 PM | #31 |
Drives: Really Fast Join Date: Aug 2017
Do you realize it was in the high 80’s low 90’s today in Austin? Way over ISA. High density altitude. High DA = poor performance. Poor performance plus spinning tires = really really poor performance.
THIS SPACE FOR RENT
06-12-2019, 09:28 PM | #32 |
Drives: ZL1 1LE A10 Join Date: Mar 2015
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
06-12-2019, 09:30 PM | #33 |
Drives: 2018 Mosaic Black Metallic ZL1 A10 Join Date: Sep 2017
Yes by a good margin. Actually have the PDR on back-to-back sessions where I switched back to the stock air box and green filter and the throttle response and acceleration/terminal speed is much better taking the Rotofab off. I went out with the stock air box / green filter after the Rotofab so the da wasn’t even as good because it was a couple of hours later and it still was 3-4 mph faster to certain points on the track that I usually mark. Have never posted this because I didnt want to appear to be bashing a vendor that’s supplying stuff for our cars. I’m sure with a tune and other stuff done the Rotofab is the way to go. It’s a great looking piece and I was sorta bummed at the way my car ran with it. I do have the Tony Mamo ported TB and that is a mod that I feel definitely helped.
06-12-2019, 09:32 PM | #34 |
Supercharger will likely be more affected by heat than a N/A motor like the SS.
But even 110 degree weather can't make a ZL1 feel slow. Something smells fishy. Expectations too high? Solution is simple. 1. Do a 0-60 run and compare notes with others in your area. 2. Dyno. A few bucks on a dyno test is worth it to put your mind at rest.
06-12-2019, 09:34 PM | #35 |
Thank you Al Oppenheiser!
Bleed the SC coolant loop.
06-12-2019, 09:35 PM | #36 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
I have both a 2SS (far from Stock) and a ZLE, it is not even close IMO. Even with the headers and catless sound, the 2SS is noticeably slower.
06-12-2019, 09:44 PM | #37 | |
Drives: 2019 ZL1 A10 Join Date: Jan 2019
This. With more vehicles owned than I can count, this car is a monster in every way. Something odd here. |
06-12-2019, 10:46 PM | #38 |
Drives: 19' ZL1 1LE Join Date: Nov 2015
This car is actually very well composed to me. Can be deceptive..
06-12-2019, 10:53 PM | #39 |
I haven’t tried the car yet with the nannies off! I will have to try it!
06-12-2019, 10:56 PM | #40 | |
Drives: 18 ZL1 A10 Join Date: Nov 2008
When you are driving around town, I will agree, pedal effort sucks, I think that's more because of the 10 inch converter. make sure you are always in SPORT. that's when the tranny gods take control and crazy shifting happens,,
ZL1::J-E-T-S JETS JETS JETS |
06-12-2019, 11:19 PM | #41 |
This car really needs to get on a 1/4 mile track and get a full run so we can break it down.
If you're spinning on 0-60 use launch control and see what happens. It's not the fastest way but it is consistent and you should have repeatable times along with some practice using some of the tools available. I'm betting you'll break 4.0 which is really a normal time with wheel spin. As mentioned the Z is very refined and can be deceptive. |
06-13-2019, 05:30 AM | #42 | |
Car in Sport, Suspension in Sport or Track, Exhaust in Track, Steering in Sport... and top down of course of you can. Nothing slow or sluggish about it. |
Tags |
camaro zl1 2019 |
