07-11-2017, 09:27 AM | #29 |
Drives: '17 Zl1, '16 Viper ACR, '15 CLA 45 Join Date: Nov 2014
Anyone wanna chip in ill buy a set then post them right away
07-11-2017, 09:56 AM | #30 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
Offsets please!
07-11-2017, 03:55 PM | #31 |
Drives: ZL1 1LE Join Date: Oct 2016
CONFIRMED Thanks to your friendly mod Mr.W
19x11 +11 19x12 +41
07-14-2017, 04:24 PM | #32 | |
Drives: 2015 ZO6 stingray 3LZ Z07 package Join Date: Feb 2014
ZL1 1LE Wheels
Hope this helps all of you, Took a while i was busy 😂😂😂😎 |
07-14-2017, 04:37 PM | #33 |
Hi y'all the rear tires and wheels are fine they dont rub any where, The front are also ok but they do stick out like 1/4 inch I will post a video if i can or more picks i know everyone is anxious hang in there
07-19-2017, 10:51 PM | #34 |
So I was lucky enough to be able to try a set of ZL1 1LE wheels on my SS 1LE tonight to test the fitment. A few people, including myself, were very interested to find out the specs of these wheels to determine if they would fit cars with mag ride, well, we know the answer now.
The answer is two fold, and not quite as straight forward as you may think. If you are running aggressive front camber (i.e. anything more than factory) they WILL NOT fit without a spacer. I say again, they DO NOT fit if you have an aggressive front alignment without the use of a 5mm spacer. I currently have -2.6* of camber and the wheels would not bolt up. I had a 3mm spacer laying around and it allowed me to fully bolt up the wheels, however, the lip of the rim just ever so slightly rubbed the strut. I made a u-turn in the street and the metal to metal rub was very noticeable during the turn, fine when driving straight. So what does this mean? The answer is that if you do not track your car and you maintain the factory alignment specs, these wheels will clear just fine. If you run any added negative camber to the front, you will need a spacer. For clarification the wheel specs are: 19x11 et11 19x12 et41 As these share the same front wheel specs as the Z28 wheels, which we have seen before, just like those they poke out quite a bit on the front. Add an extra 2mm from what you see in the pictures below to imagine how it would look with a 5mm spacer. Personally , if I were going to run these they would be a track only wheel and the poke wouldn't matter. I'd be hesitant to run these as a street wheel though, as you will get quite a bit of road grime being thrown at the paint. One solution is the addition of the C7 Z06 fender flare like a fellow member did on his SS 1LE, this would nearly cover the poke at the top of the wheel. Another, more expensive option would be to try to fit the wider ZL1 fenders. Of course, this isn't an issue if you already have a ZL1. We already know how these wheels will look on a ZL1... *cough* ZL1 1LE... *cough*. However , for you ZL1 owners keep in mind that we do share the same mag ride struts, so you too will need a 5mm spacer, thus it will probably poke a tad on your cars as well. To reiterate, below is an SS 1LE with -2.6* F camber and a 3mm spacer.
07-20-2017, 02:40 AM | #35 |
Any idea where they are hitting? Is it where the metal tabs are on the shock?
07-20-2017, 10:09 AM | #36 |
Yes.
07-21-2017, 08:56 PM | #37 |
Drives: 2017 ZL1 Join Date: Oct 2016
Great detective work wheel gurus! What about normal 20" SS wheels on a zl1? Would that work? Im trying to figure out if my winter setup will work on there..
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
08-11-2017, 07:20 PM | #38 |
Drives: None Join Date: Dec 2016
So how have those ZL1 1LE wheels been so far? I am really interested in getting these wheels when I pickup my ZL1.
If anybody else on this forum have bought these wheels, would like to know how they have been. |
12-19-2017, 03:54 PM | #39 |
Drives: ZL1 A10 Join Date: Dec 2017
It would seem that if one added the now available DSSV suspension the OEM spec wheels would fit fine with the added neg camber. Correct?
12-19-2017, 09:42 PM | #40 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
I think it was already discussed before that if you were to run this wheel tire combo on a regular ZL1 or SS 1LE, you would definitely need to trim the struts as shown in the pictures and set your camber to stock. You could gain your negative camber back by installing camber plates and use them instead of the adjustments at the spindle/hub area. As you adjust the top of struts in for max negative camber this leaves wheel clearance on the lower strut area.
Swift....Silent....Deadly
12-20-2017, 07:05 AM | #41 | |
12-20-2017, 10:21 PM | #42 | |
1st Civ. Div.
Thread Tools | |
