Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 08-05-2016, 09:12 AM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
6th Generation Camaro SS,LT,LS ACS Side Rockers 48-4-005 Available at RPI Designs
2016-2018 6th Generation Camaro SS,LT,LS ACS Side Rockers 48-4-005
https://www.rpidesigns.com/shop/item...kers-48-4-005/
These side rockers will improve the lateral airflow of your Camaro while protecting the side bodywork from rock chipping. These brand new side rockers offer a complete compatibility with our Gen6 Splitter the splitters. Rockers are manufactured in ACS's proprietary OEM validated RTM Composite Process. It means the process has been tested and proven to withstand stringent durability standard set by your car's manufacturer, the result; a superior made product designed and tested to last.
The ACS Rockers are installed over your current rocker panel, they will fit the Camaro SS V8, V6 and I4, coupe and convertible models without the GM aero package. The installation process is simple, takes just 30 minutes per side to install. There is no use of filthy adherent or two-way tape or removal of any components from your Camaro.
What Is The Importance Of Side Rockers? Airflow management and rock chip protections. The Brand New Side Rockers directly fit on the OEM rocker panels. This rocker panel plays a vital role to ensure the side bodywork is not eroded from the sticky front performance tires. You will quickly realize their sticky nature is great for its enhanced handling but will compromise the paint finish of your car.
The Brand New Side Rockers For The 2016 Camaro features
Strengthens aerodynamics
Gives an aerodynamic shape to the car, which reduces the tremendous air resistance during high-speed driving.
Most likely the most surprising feature; Maintains vehicle's ride height.
Enhanced rock chip protection by covering the side bodywork from rocks and pebbles projected from the spinning front tires.
Increased undercarriage surface; the non-visible portion of the car is double to fully covered the body colored rocker of your car.
The underside of rocker coated with a bed liner type material for a clean and durable undercarriage for years to come.
The kit is included with following items:
Rocker Panel –Passenger side
Rocker Panel - Driver side
18 Aluminium Black Split Rivets
Set of Instructions
Available Finishes
Black Primer Carbon Flash Metallic Black or painted Any 6th Generation Camaro body color.
Application Guide
Camaro Coupe V8, V6, & I4
Camaro Convertible V8, V6, & I4
RPI Designs is offline   Reply With Quote
Old 05-06-2017, 07:28 AM   #2
zeekle
Drives: 2017 Camaro 2SS
404 error on your links
zeekle is offline   Reply With Quote
Old 05-08-2017, 02:12 PM   #3
RPI Designs
Fixed. Thanks for letting us know.
Old 07-08-2018, 08:47 AM   #4
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPIDon is offline   Reply With Quote
