Old 05-21-2018, 05:30 AM   #15
motorhead
Its crazy that one must use wire ties to hold their $65,000 to $70,000 dollar car together.
Old 05-21-2018, 07:12 AM   #16
msawyer110
msawyer110's Avatar
Drives: 2017 ZL1
Mine went straight to service when i bought it cause i noticed that on passenger side. They fixed it, 2 weeks later the drivers side did it. So i just left it.
2017 ZL1 Hyper Blue Metallic M6
1996 Z28 Polo Green F1-D Procharged 383- 490rwhp
msawyer110 is offline   Reply With Quote
Old 05-21-2018, 07:56 AM   #17
devnull
Scientific negotiator
devnull's Avatar
Drives: 2019 Grand Sport
I was on the bubble between leaving it and attempting a simple fix. I would’ve done the same as you did if I noticed it before pickup too! Fortunately it seems to be pretty easy to pull in so I’m not too worried about it now (did bug the crap out of me before I popped the tail light though!)
Yes. YES IT DOES HAHA!
devnull is offline   Reply With Quote
Old 05-21-2018, 08:05 AM   #18
Alain
Alain's Avatar
Originally Posted by URBAN LEGEND View Post
Dealer will find a way to ass drag their butts on your seats and create more issues elsewhere.
This is so sad but true
2018 ZL1 1LE/Red hot
Old 05-22-2018, 08:09 PM   #19
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Ours does it when it sets in the sun. It's definitely heat related.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 05-22-2018, 08:16 PM   #20
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
I noticed this too.
nancygrl is offline   Reply With Quote
Old 05-23-2018, 12:55 AM   #21
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
This is also an issue on my SS 1LE. I've been too lazy to worry about it, but the ziptie method looks promising!
R3ctivision is offline   Reply With Quote
Old 06-17-2018, 09:46 PM   #22
devnull
devnull's Avatar
Just a note, I’ve done this on both sides now and it’s held up in both the heat and cold. Seems to be better than watching a dealer try haha...
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
Old 06-17-2018, 11:24 PM   #23
ScottMZ3
ScottMZ3's Avatar
Drives: 2018 ZL1 A10, 2019 BMW X5
Thanks for the update! I still need to get this done. With temps in the 90s now I keep noticing the issue. Bugs me!
2018 Nightfall Gray Metallic Camaro ZL1 - A10
Purchased 9/23/2017
ScottMZ3 is offline   Reply With Quote
Old 06-18-2018, 11:59 AM   #24
TeleZL1
TeleZL1's Avatar
Drives: 2018 ZL1
Yup, 18 ZL1 here....after some hard driving in the heat the same thing happens. Once it cools down they sink back in. Crazy.....thought it was just me.
TeleZL1 is offline   Reply With Quote
Old 06-18-2018, 01:30 PM   #25
BIGTIME
BIGTIME's Avatar
Drives: 2018 ZL1
mine is the same as well as the other 6 I looked at ..........
BIGTIME is offline   Reply With Quote
Old 07-02-2018, 06:45 PM   #26
Thesilent1
Drives: 2017 camaro 2.0
Folks,
I was able to correct this pretty easily (took 15 minutes using a couple of tie wraps). If needed, I will post a full writeup on how to remove the tail light but for the below just assume you have it off already (it is easy). If you search online there a ton of youtube videos on it since many of the SS guys (myself included) swapped out our red tail lights for these awesome 1LE ones!
Here is a before pic of the badly misaligned bumper. Ouch!
Remove the tail light and you will see that just under it are the tabs that the rear bumper hang on. These tabs do not hold the bumper tight enough, so we are going to help it a little.
Use a couple of tie wraps on the inside edge of the tabs and pull tightly while someone holds the bumper into the right alignment spot. Those tie wraps will pull the bumper into place and hold it into the right spot. (see below)
Put the sucker back together and behold your properly aligned bumper for your very expensive Camaro!
What youtube channel because i cant find it on youtube
Thesilent1 is offline   Reply With Quote
Old 07-02-2018, 09:11 PM   #27
pvolcko
Drives: 2018 A10 ZL1
Mine is slightly sticking out, but no where near as bad at depicted above. Not enough that I think it's worth trying to fix it. Probably do more annoying damage trying to fix it than if I leave it alone.
pvolcko is offline   Reply With Quote
Old 07-03-2018, 07:34 AM   #28
24v
Drives: 2018 SS
Just type this into the search bar on Youtube... "6th gen camaro tail light". There are a bunch of videos.
24v is offline   Reply With Quote
