07-03-2023, 01:24 PM | #1 |
Drives: 2022 summit white Chevy Camaro 2SS Join Date: Mar 2023
LT4 blower vs after market
Sorry if the title is misleading, but I was curious as to why people go with the lt4 blower on their lt1 vs an aftermarket blower tailored to the lt1 like a whipple or Maggie? From what I’ve seen it isn’t too much cheaper, is there something I’m missing?
07-03-2023, 03:59 PM | #2 |
Because it is much cheaper, and also adequate for builds targeting ZL1 power levels. Where have you seen similar prices for a secondhand LT4 supercharger vs a Maggie or Whipple?
07-03-2023, 05:28 PM | #3 | |
Since then, port jobs like the X Port have blurred that line substantially and you can definitely hustle with a 1.7 for sure. But if you want big power and low IATs, the Maggie 2650 and Whipple 3.0 flat out kill it.
07-04-2023, 01:27 AM | #4 |
From what I’ve seen, just the blower is 2-3000 and the parts needed to bolt on to an LT1 are another 2500-3000, putting you at around ~5000
07-04-2023, 05:49 AM | #5 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Still cheaper than the Maggie 2650 or Whipple 3.0 which will set you back ~ $8k for the blower only.
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
07-04-2023, 11:03 AM | #6 |
You can find 1.7's ported for that money. Shop around and buy a ported one, buy the accessories needed for install, put the savings towards a fuel system. Ported 1.7's will support 850whp pretty easy without meth on E85. If you want 1000+ then go for a big blower.
2016 NFG 1SS A8
07-04-2023, 07:06 PM | #7 | |
07-04-2023, 08:16 PM | #8 |
I just seen one posted on FB for 1600.00 shipped with 14k miles in the Dallas area.
2016 NFG 1SS A8
07-04-2023, 09:38 PM | #9 |
OP, here’s an older post discussing supporting parts. Might be helpful down the road or if you just want some more information for an install.
IIRC, this link was for an Edelbrock install but I believe this parts list will cover most of what is needed. https://www.camaro6.com/forums/showthread.php?t=583211 ADM has some parts too. https://lsa-conversion-store.myshopi...1-d6733148f22f
07-04-2023, 10:39 PM | #10 |
From what I have read (and someone with more experience can correct me if I am wrong) the 1.7 is more responsive in the lower RPM’s than a 2650 or a whipple. I have read where people say the Maggie is more like a centrifugal where the power comes on higher in the rpm’s.
2022 SS 1LE - Summit White
2023 ZL1 On Order (Unless I supercharge the 1LE first...) |
07-04-2023, 10:40 PM | #11 | |
07-05-2023, 03:52 PM | #12 | |
https://www.camaro6.com/forums//showthread.php?t=563617
