TireRack
Old 10-19-2021, 08:34 PM   #1
Bluto 2010
Drives: 2010 chevy camaro ss
New build
Hey y'all, I'm rebuilding the car because I broke the bottom end. Going back with a Fasttimes Mororworks 427, All Pro heads, larger twin 7675, and a Smallwood solid roller. The car currently has twin 6766, solid roller, sbe, btr shaft rockers, an m6 on proefi. It made 963 whp at 16psi on a run cut short at 6050 because my tuner didn't want to run it any higher. It peaked at 7300 on all prior runs. I believe the new combo will make 1600. Tell me what you think.
Bluto 2010 is offline   Reply With Quote
Old 10-20-2021, 04:22 AM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Sounds like you need a new tuner to start with if they didn't want to rev it past 6k rpm. What fuel do you intend to run?
It will definitely be enough motor and turbo to make the power, just can't be afraid to run 35+psi and rev it out with the solid roller
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 10-20-2021, 05:51 PM   #3
Bluto 2010
It was an sbe and he didn't want to push it too far. We took it to 7300 on lower boost pulls, but on the 16 psi pull it jumped to 963 at 6000 and he cut the run short.
Old 10-20-2021, 05:52 PM   #4
Bluto 2010
Oh it will be on e85.
Old 10-20-2021, 06:01 PM   #5
ttshovel
ttshovel's Avatar
E85, a nice a/w intercooler, and a bunch of boost and no reason you won't make big power. It took 40psi for me to make 1620 through a th400 and big tire on m1.
