01-17-2021, 08:13 AM | #1 |
Drives: 2020 SS 1LE Join Date: Jan 2020
Stalled on Interior Removal
I know this will come out funny. As I am taking apart my interior and want to be so careful with the speaker clip. I already broke my under-seat airbag clip, so I would not like to create more work that necessary.
The picture below shows the passenger rear side speaker. There is a black clip which connects the wire to the interior panel mounted speaker. It has a red piece which slides back and fourth. It looks as though you simply slide the red piece away from the speaker and pull the black clip apart. However, using a fair amount of force i've had no luck. Am I missing something? |
01-17-2021, 08:27 AM | #2 |
Drives: 2020 Chevy Camaro Join Date: Oct 2019
the red clip is just a lock, you pull it like you did but afterwards you still need to press the little lever for it to disengage just like any other car. All the connectors in the camaro are done this way
01-17-2021, 11:05 AM | #3 |
Thanks pumalex I found it, I couldn't see the black lever first pass. Easier to see during the day.
